    Copying files using "ftools.rb" library
    5 Posts 2 Posters 2.1k Views 2 Watching
    • M
      mgate
      I aim to copy a SketchUp file from one folder to another. I'm using the following method from the "ftools.rb" library:
      def copy(from, to, verbose = false)
          $stderr.print from, " -> ", catname(from, to), "\n" if verbose
          syscopy from, to
        alias cp copy
      when running my plugin, the file is copied correctly from the original folder to the destination folder but SketchUp crashes afterwards.
      SketchUp Application has stopped working
      A problem caused the program to stop working correctly.
      Windows will close the program and notify you if a solution is available.
      I tried different options, i.e. keeping the same "to" file name as the "from", also changing it but SketchUp always crashes.
      However, when using the move method of the "ftools.rb", it works perfectly with no problem even changing the "to" name:
        def move(from, to, verbose = false)
          to = catname(from, to)
          $stderr.print from, " -> ", to, "\n" if verbose
          if RUBY_PLATFORM =~ /djgpp|(cyg|ms|bcc)win|mingw/ and file? to
            unlink to
          fstat = stat(from)
          begin
            rename from, to
          rescue
            begin
              symlink readlink(from), to and unlink from
            rescue
      	from_stat = stat(from)
      	syscopy from, to and unlink from
      	utime(from_stat.atime, from_stat.mtime, to)
      	begin
      	  chown(fstat.uid, fstat.gid, to)
      	rescue
        alias mv move
      Any idea where the problem is? Thanks for your time.
      Note: I use SU v8
      • Dan RathbunD
        Dan Rathbun
        (1) SU v8 uses Ruby 1.8.x which does not have Unicode character support on Windows. So any unicode characters in the pathnames could cause issues.
        (2) Symbolic links require being logged into an administrator account on newer Windows version (I believe v6.0 [Vista] and higher.)
        Lastly, you haven't said what kind of file you are copying. ?
        Is the file currently in use by SketchUp or your extension ?
        I'm not here much anymore.
        • M
          mgate
          The goal is to create a copy of two existing template files (not opened) from "Resource" folder to a different path, the target files should have new names too (previously defined in a inputbox).
          templates:
          ...\Resources\XXX AT Template.skp
          ...\Resources\XXX AT Template.xlsx
          Here it is part of the script of my plugin, at the moment just trying to copy the skp file though:
          require 'ftools.rb'
          folder		= File.dirname( __FILE__ )
          resources	= "Resources"
          resource_name= "XXXXXX AT Template.skp"
          resource_file	= File.join(folder, resources, resource_name).tr("\\","/") # the script will be modified to select the directory via a UI.savepanel dialogue
          file_name	= "123456 AT aa.bb.skp"  # the real name will be picked via an inputbox
          desti_file	= File.join(folder, file_name).tr("\\","/")
          if File.exist?(resource_file)
           File.copy(resource_file, desti_file, verbose = true)
          else
           puts "SKETCHUP TEMPLATE FILE NOT FOUND!"
           return nil
          The above script certainly creates the copy in the correct folder but SU crashes afterwards.
          As the move() doesn't crash, I tried to modify it as follow:
          #    if RUBY_PLATFORM =~ /djgpp|(cyg|ms|bcc)win|mingw/ and file? to
          #      unlink to
          #    end
              fstat = stat(from)
              begin
          #     rename from, to
          #  rescue
                begin
                ln from, to and unlink from
                rescue
          	begin
          	rescue
            alias mv move
          by using above move(), the resource_file is kept and the desti_file is created but SU crashes too.
          I tried to use Fileutils.rb instead but there are lots of errors when open SU v.8 (I'm using !AdditionalPluginFolders.rb) and below doesn't work:
          FileUtils.copy_file(resource_file, desti_file, preserve = false, dereference = true)
          • Dan RathbunD
            Dan Rathbun
            Is the above code within a method? Using local variablesin the TOPLEVEL_BINDING of a script will not work. (They are removed from memory when the script ends.) They should be instance or class variables instead.
            @mgate said:
            require 'ftools.rb'
            Where did "ftools.rb" come from ?
            Where did you get the "FileUtils.rb" file from ?
            I have a properly versioned Ruby 1.8.6-p287 standard Ruby library packaged as an RBZ extension for SketchUp v8..13 here:
            https://github.com/DanRathbun/sketchup-ruby186-stdlib-extension/releases/latest
            @mgate said:
            (I'm using "!AdditionalPluginFolders.rb") and below doesn't work:
            Using this just adds complexity to the issue at hand. I'd suggest removing it from the equation. And fix the underlying issue.
            • Dan RathbunD
              Dan Rathbun
              @mgate said:
              require 'ftools.rb'
              Problem here.
              The "Resources" folder is not in a sub-folder of the "Plugins" folder, nor in a sub-folder of YOUR extension sub-folder (which should be in a sub-folder of "Plugins".)
              This should return the correct path:
              resource_path = Sketchup.find_support_file("Resources")
              The above script certainly creates the copy in the correct folder but SU crashes afterwards.[/quote]
              Do you get a BugSplat!, or is a Windows Error Report (WER) generated (ie, check Event Viewer) ?
              Secondly, your rescue clauses are not telling you what error is happening. Do something like this:
              begin
                # file operation
              rescue => e
                puts e.inspect # or UI.messagebox(e.inspect)
              else # change to more meaningful message;
                puts "file operation success!"
              Thirdly, we used to tell users to run SketchUp as administrator because all users needed read and write permissions on folder in the SketchUp application's program path. (This can cause file drag and drop to stop working for SketchUp.)
              The alternative is to set permissions for SketchUp and all it's program sub-folders to allow all users full permissions.
