    Help creating a dimension
    1 Posts 1 Posters 803 Views 1 Watching
    • I Offline
      ittayd
      I'm using the latest Sketchup Make (2017). I have the attached model. What I'm trying to do is create a dimension that will be a duplicate of the one in the drawing. So I select the dimension and then in the console:
      ss = Sketchup.active_model.selection
      #<Sketchup;;Selection;0x00000010cf1e20>
      dim = ss[0]
      #<Sketchup;;DimensionLinear;0x00000010d20680>
      dim2 = dim.parent.entities.add_dimension_linear(dim.start, dim.end, dim.offset_vector)
      #<Sketchup;;DimensionLinear;0x00000011dd0570>
      dim.hidden = true
      true
      The new dimension is not seen, nor selected when I do ctrl-A. Furthermore:
      dim.start
      [#<Sketchup;;Vertex;0x00000011ac4a20>, Point3d(-4.19399, -68.4499, 42.0472)]
      dim2.start
      [#<Sketchup;;Vertex;0x00000011ac4a20>, Point3d(68.4499, 0, 42.0472)]
      So the two dimensions are attached to the same vertex, but with different points. The following doesn't work either:
      dim3 = dim.parent.entities.add_dimension_linear([dim.start[0], dim.start[1]], [dim.end[0],dim.end[1]], dim.offset_vector)
      #<Sketchup;;DimensionLinear;0x0000001363d018>
      dim.start
      dim3.start
      Is this a bug or am I doing it wrong?
      dims.skp
