    SKUI - Retrieve text from Textbox when clicking button
    5 Posts 3 Posters 1.2k Views 3 Watching
    • F
      Finfa811
      I'm trying SKUI and I have created a Window with a Textbox in this way:
          w = SKUI;;Window.new
          txt_box = SKUI;;Textbox.new( "" )
          txt_box.name = ;txt_name
          txt_box.position( 155, 27 )
          txt_box.width = 200
          w.add_control( txt_box )
          label = SKUI;;Label.new( 'Label', txt_box )
          label.position( 10, 30 )
          w.add_control( label )
          btn_cancel = SKUI;;Button.new( 'Cancel' ) { |control|
            return nil
            control.window.close
          btn_cancel.position( -5, -5 )
          w.add_control( btn_cancel )
          btn_ok = SKUI;;Button.new( 'OK' ) { |control|
          btn_ok.position( -100, -5 )
          w.add_control( btn_ok )
          w.cancel_button = btn_cancel
          w.default_button = btn_ok
          w.show
      After that, I type something in the Textbox and I would like to retrieve the string when I click btn_ok. I know the string should be in txt_box.value, but I don't know how to update the value of the TextBox when clicking a button. It is always empty. Do you know how to do it?
      • sdmitchS
        sdmitch
        Better ask ThomThom, he knows.
        http://sdmitch.blogspot.com/
        • F
          Finfa811
          @sdmitch I've already fixed it. Thank you anyway.
          • Dan RathbunD
            Dan Rathbun
            Local references go out of scope and are garbage collected when a method ends.
            You need to have some persistent references within your plugin's scope (module or class) to accept the values. This also means you need to use persistent reference for the dialog itself (ie, @w not w.)
            btn_ok = SKUI;;Button.new( 'OK' ) {|control|
              @txt_box_value = txt_box.value
            I'm not here much anymore.
            • F
              Finfa811
              Exactly Dan, that was one of my mistakes. Finally I got it by myself, and now I understand the basics. Thank you in any case.
