    Get data from already opened workbook
    4 Posts 2 Posters 854 Views 2 Watching
    • D
      davesexcel
      I have a workbook, that I use to input the values for the sketchup to draw. I seems to be working fine but would like it to be able to get the info from the workbook that is already opened, not having to open the workbook to get the data. Is there a way to get the info from an active workbook?
      This way when I run the code, it will get the info and insert the picture onto the sheet.
        UI.menu("PlugIns").add_item("Get From Excel") { get_from_excel }
      require('win32ole')
      	 def get_from_excel
      ents=Sketchup.active_model.active_entities
      require 'win32ole'
      xl = WIN32OLE.new('Excel.Application')
      xl.visible=1
      wb = xl.Workbooks.Open('C;\TestFolder\Stair_Info_to_Sketchup.xlsm')
      worksheet = wb.Worksheets('Sheet1')
      worksheet2 = wb.Worksheets('Sheet2')
      ent = Sketchup.active_model.entities
      Sketchup.active_model.entities.clear!
      rise=worksheet.range('a2').value
      run=worksheet.range('b2').value
      b=worksheet.range('i2').value
      d=worksheet.range('h2').value
      c=worksheet.range('c2').value
      dado=worksheet.range('d2').value
      ns=worksheet.range('e2').value
      e=worksheet.range('f2').value
      wdth=worksheet.range('g2').value
      tr=7
      g=1.25
      f=worksheet.range('j2').value
      h=0.5
      ent.add_line [0,(run+1)+0*run-1.5,rise-c], [0,(1.5+0*run)-1.5,rise-c]
      ent.add_line [0,1.5+0*run-1.5,rise-c+dado], [0,1.5+0*run-1.5,rise-c]
      ent.add_line [0,1.5+0*run-1.5,rise-c+dado], [0,1+0*run-1.5,rise-c+dado]
      ent.add_line [0,1+0*run-1.5,rise-c+dado], [0,1+0*run-1.5,rise-c]
      edg = ent.add_line [0,1+0*run-(1+0.5),rise-c],[0,e+0*run-(ns+1),rise-c]
      edg = ent.add_line [0,e+0*run-(ns+1),rise-c],[0,e+0*run-(ns+1),rise]
      edg = ent.add_line [0,e+0*run-(ns+1),rise],[0,(run+1)+0*run-1.5,rise]
       edg=ent.add_line [0,1+run-1.5,rise],[0,1+run-1.5,rise-c]
              edg.find_faces; face=edg.faces[0]
                face.pushpull wdth
         group1 = ent.add_group face.all_connected ;group1.name="Tread"
      		  group1.description="Tread"
      #loop through treads--------------------
      for i in 1..tr-2
        group2 = group1.copy
        tran = Geom;;Transformation.translation [0, run*i, rise*i]
      group2.transform! tran ;group2.name="Treads"
        #---Good
         group = ent.add_group(); group.name="Bottom riser"
      ent2 = group.entities
       pts = []
       pts[0] = [0, 0, 0]
       pts[1] = [0,-e,0]
       pts[2] = [0, -e,rise-c+dado]
       pts[3] = [0, 0, rise-c+dado]
       # Add the face to the entities in the model
      face = ent2.add_face pts
       face.pushpull wdth
       group.description = "Bottom riser"
       #---good
       group = ent.add_group(); group.name="Riser"
      ent3 = group.entities
       pts = []
      pts[0] = [0, run, rise-c]
      pts[1] = [0,run-e,rise-c]
       pts[2] = [0, run-e,2*rise-c+dado]
       pts[3] = [0, run, 2*rise-c+dado]
      face = ent3.add_face pts
       face.pushpull wdth
      group.description = "Riser"
      for i in 1..tr-3
        group2 = group.copy
        #----good
        #<<<<<<Top Hanger
        group = ent.add_group(); group.name="Top riser"
         ent5 = group.entities
       ent5.add_line [0,b-2,d-c], [0,b-2,d-(rise+1)]
        ent5.add_line [0,b-2,d-(rise+1)], [0,b-2+h,d-(rise+1)]
        ent5.add_line [0,b-2+h,d-(rise+1)], [0,b-2+h,d]
          edg=ent5.add_line [0,b-2,d-c], [0,b-2-1,d-c]#<<<< edg
        ent5.add_line [0,b-2-1,d-c], [0,b-3,d]
        ent5.add_line [0,b-3,d] , [0,b-2+h,d]
        face.pushpull wdth
       #<<<<<<<<<<<<<<<Stringer
              # offset vectors for rise and run
      		group = ents.add_group(); group.name="Stringer"
      		ent1 = group.entities
              risevect = Geom;;Vector3d.new([0,0,0], [0,0,rise])
              runvect = Geom;;Vector3d.new([0,0,0], [0,run,0])
      	#<<<<<<<<<<<<<<#last tread
              lstrun = Geom;;Vector3d.new([0,0,0], [0,(run-e),0])
      	#<<<<<<<<<<<<<<<<<<<<Move Stringer
      	ms= Geom;;Vector3d.new [(-wdth-g),0,0]
      	ms2= Geom;;Vector3d.new [-wdth/2+g/2,0,0]
      		#<<<routed stringer
        group = ent.add_group(); group.name="Routed Stringer"
         ent6 = group.entities
         pts = []
         pts[0] = [0,b-(1+e),d]
         pts[1] = [0,b-(4+e),d]
         pts[2] = [0,-3, rise]
         pts[3] = [0, -3, 0]
          #calculate pts 4 & 5
        vec = pts[2].vector_to(pts[1])
        v = vec.axes[1].reverse
        tpt = pts[2].offset(v,f)
        pts[4]=Geom.intersect_line_line [pts[3],[0,1,0]],[tpt,vec]
        #pts[4] = [0,(run+2.5)*0.4256, 0]
        pts[5] = Geom.intersect_line_line [pts[0],[0,0,1]],[tpt,vec]
        #pts[5] = [0, b-(1+e), (d-12 )]
             #add the face to the entities in the model
          face = ent6.add_face pts
          face.pushpull g
          group.description = "Routed Stringer"
      	#copy routed stringer
       group1 = group.copy
        tran = Geom;;Transformation.translation ms
      group1.transform! tran
      #-----Pictures Insert Code---------------
       #require 'win32ole'
       model = Sketchup.active_model
       entities = model.active_entities
       view = model.active_view
       # Puts in SketchUp install directory by default
       status = view.write_image "test.jpeg"
       keys = {
         ;filename => "S;/Stairs/Stair Pics/write_image.jpeg",
         ;width => 500,
         ;height => 400,
         ;antialias => false,
         ;compression => 0.5,
         ;transparent => false
       new_view = view.zoom_extents
       view.write_image keys
      pic = worksheet.Pictures.Insert('S;\Stairs\Stair Pics\write_image.jpeg')
      range = worksheet.Range('A5;F20')
      pic.ShapeRange.LockAspectRatio = false
      pic.Top = range.Top
      pic.Left = range.Left
      pic.Width = range.Width
      pic.Height = range.Height
      • Dan RathbunD
        Dan Rathbun
        @davesexcel said:
        ... but would like it to be able to get the info from the workbook that is already opened, not having to open the workbook to get the data. Is there a way to get the info from an active workbook?
        Have you seen my example here in this forum ?
        [Code] Geometry Creation from Excel worksheet data
        It has a method that first checks to see if Excel is already open. And it is properly module wrapped (but you should change the name of the outer module at least.)
        I'm not here much anymore.
        • D
          davesexcel
          Thanks Dan,
          I did find that, just can't get it to work< using all sorts of options, It seems to want to open up a new excel, and not use the existing excel. So it errors when finding the range.
            require 'win32ole'
          #WIN32OLE.connect('Excel.Application')
          xl = WIN32OLE;;connect('Excel.Application')
          xl.visible=1
          #wb = xl.Workbooks('TestAddImage.xlsm')
          puts "a"
          worksheet = xl.activesheet
          puts "b"
          #worksheet2 = xl.Worksheets('Sheet2')
          puts "c"
          worksheet.Range('a1').Value=1111
          worksheet.Range('a2').Value
          • D
            davesexcel
            Wow, I got it to work!!
            require 'win32ole'
            xl.visible=1
            worksheet = xl.Worksheets(1)
