    Trouble finding faces
    2 Posts 2 Posters 646 Views 2 Watching
      davesexcel
      I am using an If else statement, I got it to work earlier in the code, but now I am having an issue grouping a new entity and finding it's face, it has to do with adding an arc and not adding an arc.
      How would one name a group and find the faces in this situation?
      Arc and no Arc
       ents=Sketchup.active_model.active_entities
      		prompts = ["Stair Width", "Travel","Tread Thickness","Total Height","Riser Thickness","Stringer Width","Stringer Thickness","Top Hanger Thickness","Customer","Customer Address","Top Hanger Nose","Round Nose","Flight","No Nose"]
          defaults = [36.0,51.5,1.5,46.5,0.5,11.25,1.25,0.5,"My Builder", "234 Jimmys street","Yes","Yes","Main","Yes"]
      	list=["","","","","","","","","","", "Yes|No","Yes|No","Main","Yes|No"]
          input = UI.inputbox prompts, defaults,list, "Stair Info"
              a,b,c,d,e,f,g,h,i,j,k,l,m,n=input
      		cst=i.to_s
      		adr=j.to_s
      ent = Sketchup.active_model.entities
      	tr=(d/8.0).ceil
      	rise=d/tr
      	run=((b-(1+h))/(tr-1))
      wdth=a-2.5
      			prompts = ["Stair Width", "Number if Rises","Height","Travel","Hanger"]
          defaults = [36.0,tr,d,b,h]
      	list=[""]
          input = UI.inputbox prompts, defaults,list, "Rise and Run"
              wth,rs,b,d,h=input
      		cst=i.to_s
      		adr=j.to_s
      l
      	rise=b/rs
      	run=((d-(1+h))/(rs-1))
      		#---------Clear All
      Sketchup.active_model.entities.clear!
      		#----------------Make 1st tread
      ent.add_line [0,(run+1)+0*run-1.5,rise-c], [0,(1.5+0*run)-1.5,rise-c]
      ent.add_line [0,1.5+0*run-1.5,rise-c+0.1875], [0,1.5+0*run-1.5,rise-c]
      ent.add_line [0,1.5+0*run-1.5,rise-c+0.1875], [0,1+0*run-1.5,rise-c+0.1875]
      ent.add_line [0,1+0*run-1.5,rise-c+0.1875], [0,1+0*run-1.5,rise-c]
      #Nose Yes/No<<<<<
      if n=="Yes"
      ns=1
      else
      ns=0
      puts ns
      puts d
      #End add nose<<<
      #ROUND Nose Yes/No<<<<<<
      if l=="Yes"
         puts "Round Nose"
      #add arc<<<<<<
      edg = ent.add_line [0,1+0*run-1.5,rise-c],[0,e+0*run-1.5,rise-c];vrt1=edg.end
      ent.add_arc [0,0.5+0*run-1.5,-c/2.0+(rise)],[0,0,-1],[-1,0,0],c/2.0,0,180.degrees,12
       edg = ent.add_line [0,1+run-1.5,rise],[0,0.5-1.5,rise];vrt2=edg.start
      #end Add Arc<<<<<
      else
      edg = ent.add_line [0,1+0*run-(1+0.5),rise-c],[0,e+0*run-(ns+1),rise-c]
      edg = ent.add_line [0,e+0*run-(ns+1),rise-c],[0,e+0*run-(ns+1),rise]
      edg = ent.add_line [0,e+0*run-(ns+1),rise],[0,(run+1)+0*run-1.5,rise]
      puts "SQUARE NOSE"
        edg=ent.add_line [0,1+run-1.5,rise],[0,1+run-1.5,rise-c]
              edg.find_faces; face=edg.faces[0]
                face.pushpull wdth
      		  if l=="Yes"
      		 edgs=vrt1.edges.reject!{|e| e.length<wdth};edgs[0].soft=true
               edgs=vrt2.edges.reject!{|e| e.length<wdth};edgs[0].soft=true
      		 else
      		  group1 = ent.add_group face.all_connected ;group1.name="Tread"
      		  group1.description="Tread"
      for i in 1..tr-2
        group2 = group1.copy
        tran = Geom;;Transformation.translation [0, run*i, rise*i]
      group2.transform! tran
        #---Good
         group = ent.add_group(); group.name="Bottom riser"
      ent2 = group.entities
       pts = []
       pts[0] = [0, 0, 0]
       pts[1] = [0,-e,0]
       pts[2] = [0, -e,rise-c+0.1875]
       pts[3] = [0, 0, rise-c+0.1875]
       # Add the face to the entities in the model
      face = ent2.add_face pts
       face.pushpull wdth
       group.description = "Bottom riser"
       #---good
       group = ent.add_group(); group.name="Riser"
      ent3 = group.entities
       pts = []
      pts[0] = [0, run, rise-c]
      pts[1] = [0,run-e,rise-c]
       pts[2] = [0, run-e,2*rise-c+0.1875]
       pts[3] = [0, run, 2*rise-c+0.1875]
      face = ent3.add_face pts
       face.pushpull wdth
      group.description = "Riser"
      for i in 1..rs-3
        group2 = group.copy
        #----good
      #<<<<<<Top Hanger
        group = ent.add_group(); group.name="Top riser"
         ent5 = group.entities
       ent5.add_line [0,b+3,b-c], [0,b+3,b-15]
        ent5.add_line [0,b+3,b-15], [0,b+3+h,b-15]
          ent5.add_line [0,b+3+h,b-15], [0,b+3+h,b]
      	if l=="Yes"
      	puts "top hanger round nose"
      	  #add arc<<<<<<
      	edg = ent5.add_line [0,b+3,b-c], [0,b+3-0.5,b-c] ;vrt1=edg.end
      		ent5.add_arc [0,b+3-0.5,b-(c/2)],[0,0,b+3-1],[-1,0,0],-c/2.0,0,180.degrees,12
      			  edg =  ent5.add_line [0,b+3+h,b], [0,b+2.5,b];vrt2=edg.start
      	#end Add Arc<<<<<
      else
      puts "top hanger square nose"
       ent5.add_line [0,b+3,b-c], [0,b+3-1,b-c]
       ent5.add_line [0,b+3-1,b-c], [0,b+3-1,b]
        ent5.add_line [0,b+3-1,b] , [0,b+3+h,b]
             #add the face to the entities in the model
                face.pushpull -wdth
      • sdmitchS Offline
        sdmitch
        It seems to me that you define 'edg' twice if l=="Yes" but don't define it at all if l=='No'.
        if l=="Yes"
          #add arc<<<<<<
          #end Add Arc<<<<<
        else
          edg=ent5.add_line [0,b+3,b-c], [0,b+3-1,b-c]#<<<< edg
        face.pushpull wdth
        http://sdmitch.blogspot.com/
