    Edge observer
    2 Posts 1 Posters 723 Views 1 Watching
    • inteloideI
      inteloide
      Hello,
      For one of my plugin, I want to catch when a component is modified (ie entities inside the component are moved, stretched, erased, added, etc).
      My problem is to trigger an observer when moving an edge (single edge not attached to a face) using moving tool.
      Do do so, I placed an observer on model to catch when the active path is changed, and then add on observer on entities within active_entities :
      class MyModelObserver < Sketchup;;ModelObserver
      	@@observers = {}
      	@@previous_path=nil
      	def onActivePathChanged(model)
      		puts "onActivePathChanged "+Sketchup.active_model.active_entities.to_s
      		#remove previous observer if exist
      			if @@previous_path!=nil then
      				puts "Remove observers of "+@@previous_path.to_s
      				p @@previous_path.remove_observer(@@observers[@@previous_path])
      				@@previous_path=nil
      		#Quit if active_path is nill (no group or component is opened)
      			return if !Sketchup.active_model.active_path
      		#define observer object and try to add it to active_entities
      		#if it is successfully added, update class variable @@observers
      			observer = MyEntitiesObserver.new()
      			if Sketchup.active_model.active_entities.add_observer(observer)
      				#Save observers data
      					@@observers[Sketchup.active_model.active_entities] = observer
      					@@previous_path=Sketchup.active_model.active_entities
      				#Add observers to each entity of active_entities
      					for entity in Sketchup.active_model.active_entities
      						entity.add_observer(MyEntityObserver.new)
      class MyEntityObserver < Sketchup;;EntityObserver
      	def onEraseEntity(entity)
      		puts "onEraseEntity; #{entity}"
      	def onChangeEntity(entity)
      		puts "onChangeEntity; #{entity}"
      class MyEntitiesObserver < Sketchup;;EntitiesObserver
      	def onElementAdded(entities, entity)
      		puts "onElementAdded "
      	def onElementModified(entities, entity)
      		puts "onElementModified "
      	def onElementRemoved(entities, entity_id)
      		puts "onElementRemoved"
      	def onEraseEntities(entities)
      		puts "onEraseEntities"
      Then running the script :
      Sketchup.active_model.add_observer(MyModelObserver.new)
      I cannot see any "modification" observer triggers when when moving a simple edge not attached to a face, within a component...
      If someone can help me...
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • inteloideI
        inteloide
        Well, a start of explaination and solution, here :
        http://forums.sketchup.com/t/edge-change-observer/8184 :
        Put an observer on edge.start and edge.end
        Thanks TT !
