    Creating a timer in script
    1 Posts 1 Posters 8.8k Views 1 Watching
    • robintR
      robint
      Hi SU fans
      Can anyone help me make a timer to display the interval (secs) of a falling object hitting a baseplate (see model)
      Faust kindly contributed this to detect the object hitting the plate - it resets on impact and I loose all the time info on screen. There is no pause or stop action to replace reset AFAIK
      onTouch { |toucher, position, normal|
      MSPhysics::Simulation.reset
      I have discovered the
      start_timer and stop_timer
      action but don't know how to use it
      Ideally the interval result should be displayed on screen or otherwise accessible, and there should be a facility to have a coeff to adjust the result to the correct answer - frig factor (1s) as I noticed the on screen timer/fps is not accurate and depends on several settings (time step, linear damping et al)
      Sorry to be a Ruby newbie but trying my best 😞
      and this could be so useful for dynamic simulation validation
      Cheers
      Robin
      falling block.skp
      As one door closes another one slams in your face
