    New Mac Book Pro graphics?
    2 Posts 2 Posters 5.9k Views 2 Watching
    • JClementsJ Offline
      JClements
      I believe that Intel graphics has been an issue in the past for SketchUp.
      Does anyone have any info whether this would still be an issue with the new MacBook Pro?
        db11
        I don't have any direct experience with the new gen MacBook Pros, but from a reply I gave to a similar query on the other forum:
        I have a late 2014 13" MacBook Pro with the following specs:
        2.6 GHz Core i5 (4th Gen / Haswell)
        16 GB 1600 MHz DDR3 RAM
        Intel Iris 5100 integrated graphics
        It runs SketchUp well and drives a Dell U3415W external monitor without any problems or latency. Given that the Touchbar model is two generations newer for both CPU and GPU, (with associated increases in speed/power) it should work well. The 13" model can drive a 5K monitor with a single TB3 cable, the 15" can drive two.
        I wouldn't worry about Intel integrated graphics compatibility β€” there have been associated issues reported with Windows PC's but never heard any from recent MacBooks. Maybe because they use the higher spec'd Iris graphics (vs the lower-end HD graphics often found on PC ultrabooks)β€” plus you don't have wonky driver issues on the Mac, which support the latest OpenGL spec.
        Sorry for the cut & paste, but hope the info is marginally useful.
