    Teenager's room
    28 Posts 6 Posters 3.4k Views 6 Watching
      measuredmove
      Sorry..thought I was all done..but have 2 more questions.
      Do you re-import the KT rendered image back into TW to create the pano and are hotspots created in TW or in Pano2VR?
      I'll say Thanks in advance.
      My 3D Catalogue
      https://3dwarehouse.sketchup.com/collection/103ed44c-a0c4-4049-9a84-89cd017bcc07/Measured-Move
      SU8/Brighter3D/Gimp/SimLab Composer
      • jo-keJ Offline
        jo-ke
        No no, it is very simple.
        I do all settings in Twilight, then I make a special folder "kerky", to put the xml file and all the rest (pics, ies,...) inside. this is a one way folder. after Export everything with SU and TWL is done.
        Then I open KT, open the xml. Then I render each scene, one after another. The output is allready equirectangular, because I have choosen "spherical" in twilght.
        Be carful with layers. The xml stores the locations of the scenes but only the layers of the current scene.
        http://www.zz7.de
          In term of minutes time's render : Twillight is more /less than KT ?
            measuredmove
            Again, Thanks
            It's been a while since I used KT but I will try it out on a small project.
            My 3D Catalogue
            • jo-keJ Offline
              jo-ke
              rendertime should be the same. But the advantage is the independent renderengine. It can still render all night long at a seperate workstation and I can continue modelling in SU.
              http://www.zz7.de
                Thx for the infos!
                • P Offline
                  psylo
                  Nobody noticed the pop up screen ! πŸ˜›
                  • jo-keJ Offline
                    jo-ke
                    I was also confused. No idea what happend to that notebook. I will never use it again.
                    http://www.zz7.de
                    • 2 / 2
