    How to cut from object
    47 Posts 4 Posters 4.8k Views 4 Watching
      ado130
      It seems that it works. Is it correct way?
      Just one question, how can I delete the black lines?, or hide them.
      def drill(x, y, z, radiuses, depths, directions)
      	model = Sketchup.active_model
      	countOfDrills = x.length.to_i
      	countOfDrills.times do |i|
      		center = [x[i], y[i], z[i]].map(&;to_f)
      		radius = radiuses[i]
      		depth = depths[i]
      		direction = directions[i]
      		case direction
      			when "N"
      				dir = Geom;;Vector3d.new(0,0,1)
      			when "E"
      				dir = Geom;;Vector3d.new(-1,0,0)
      			when "S"
      				dir = Geom;;Vector3d.new(0,0,-1)
      			when "W"
      				dir = Geom;;Vector3d.new(1,0,0)
      			when "F"
      				dir = Geom;;Vector3d.new(0,-1,0)
      			when "B"
      				dir = Geom;;Vector3d.new(0,1,0)
      			else
      		groups = []
      		i = 0
      		Sketchup.active_model.entities.each{|g|
      			next unless g.is_a?(Sketchup;;Group)
      			g.entities.each{|f|
      				next unless f.is_a?(Sketchup;;Face)
      				if center.on_plane? f.plane then
      					groups.each {|x| next if g == x}
      					groups[i] = g
      					i += 1
      		groups = groups.uniq
      		countOfGroups = groups.length.to_i
      		countOfGroups.times do |i|
      			group = groups[i]
      			gents = group.entities
      			activeFaces = gents.grep(Sketchup;;Face)
      			circleGroup = gents.add_group; cge = circleGroup.entities
      			edges = cge.add_circle(center, dir, radius)
      			circleGroup.explode
      			circleFace = (gents.grep(Sketchup;;Face) - activeFaces).last
      			next if circleFace == nil
      			normal = circleFace.normal
      			circleFace.pushpull(-depth)
      			deleteFace = (gents.grep(Sketchup;;Face) - activeFaces)[0]
      			if deleteFace.normal == normal then
      				deleteFace.erase!
      • sdmitchS Offline
        sdmitch
        Try this
         group = groups[i]
         circleGroup.explode;
         (gents.grep(Sketchup;;Face) - activeFaces).each{|circleFace|
          next if center.distance(circleFace.bounds.center) > radius
         remove = gents.grep(Sketchup;;Edge).find_all{|e|e.faces.length<2}
         gents.erase_entities(remove.reverse)
        http://sdmitch.blogspot.com/
          ado130
          It seems that it works too. Thanks!
          But black lines are still there.
          You have there "]", I think, it should be "}"?
          • sdmitchS Offline
            sdmitch
            Yes, you are right. Sorry about that.
            The black vertical lines in the 'drill hole'?
              ado130
              Yeah, you're right, but I meant black lines in rectangular blocks (rather, all lines).
              • sdmitchS Offline
                sdmitch
                @ado130 said:
                Yeah, you're right, but I meant black lines in rectangular blocks.
                Well, if you didn't want them, why did you create then in the first place.
                	group = groups[i]; group.make_unique
                	activeEdges = gents.grep(Sketchup;;Edge);#<-- save active edges
                   #remove unused circle edges
                	# hide vertical edges in drill hole
                	soften = (gents.grep(Sketchup;;Edge)-activeEdges).find_all{|e|e.line[1].parallel?(dir) && !e.soft?}
                	soften.each{|e|e.soft=e.smooth=true}
                	# remove co-planar edges
                	remove = gents.grep(Sketchup;;Edge).find_all{|e|(e.faces.length>=2 && e.faces.find_all{|f|f.normal.parallel?(e.line[1].axes[1])}.length==2)}
                  ado130
                  Sorry for the delayed response. It looks fine, thanks again!
                  http://i.imgur.com/TtoBovE.png
                  • 3 / 3
