    Closest face problem
    5 Posts 3 Posters 782 Views 3 Watching
    • hsmyersH Offline
      hsmyers
      Imagine two selected objects. I'd like to determine the closest pairing of one face from each. I'll be using the faces from the bounding box of each object. My goal is to move one from the BB center to it's opposing BB center, but that is later and I've cobbled code to do so. What I'm currently doing is a distance from CP to origin and then comparing the two. It works some times and fails the rest of the time. This may be influenced by a second problem and that has to do with selection. How do I reliably tell first selection from second? Currently it's the simple minded @sel[0] and @sel[1] as first and second where @sel decends from Sketchup.active_mode.entities.selection.
      In sum, I'd like to know how to:
      • Determine closest pair of faces from two object bounding boxes?* Determine order of selections
      Will bake cookies!! πŸ˜‰
      • Dan RathbunD Offline
        Dan Rathbun
        Bounding Boxes are virtual geometric "helper" objects that do not have faces.
        @hsmyers said:
        How do I reliably tell first selection from second? Currently it's the simple minded @sel[0] and @sel[1] as first and second where @sel results from Sketchup.active_model.entities.selection.
        You will need to implement a [%(#BF0000)[SelectionObserver]](http://www.sketchup.com/intl/en/developer/docs/ourdoc/selectionobserver) subclass.
        I'm not here much anymore.
        • hsmyersH Offline
          hsmyers
          True but it is easy enough to construct the necessary 'face' and then derive the center. I should have been more clear. Hmmmm...that said, how about closest pair of points? A sorted list of 64 lengths? Or is the something less sledgehammerish?
          Ah! A little bit deeper into the tool pool...splash!! Thanks for the tip and the correction πŸ˜„ Any ideas on the revised question?
          • sdmitchS Offline
            sdmitch
            Since you are only dealing with two objects, it shouldn't matter which is sel[0] or sel[1]
            To find the closest corners of two objects
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            vue = mod.active_view
            obj0 = sel[0]; obj1 = sel[1]; cor0=[]; cor1=[]
            [0,1,2,3,4,5,6,7].each{|i| cor0<<obj0.bounds.corner(i)}
            [0,1,2,3,4,5,6,7].each{|i| cor1<<obj1.bounds.corner(i)}
            md=1e9;m=n=0
            cor0.each_with_index{|c0,i|
             cor1.each_with_index{|c1,j|
              d = c0.distance(c1)
              if d < md
               md=d;m=i;n=j
            UI.messagebox "Obj0 Cor#{m} to Obj1 Cor#{n} is #{Sketchup.format_length(md)}"
            http://sdmitch.blogspot.com/
            • hsmyersH Offline
              hsmyers
              Thank you for the snippet!
              You are correct excepting that the tool in question will move one of the two objects such that the opposing face centers are touching plus or minus an offset. Sorry for the grossly incomplete spec 😞 My plan (very fluid and quite murky ) is take the first selection as the moving object and the second as the fixed object. I've some notion about non-parallel faces requiring ( optionally ) an rotational adjustment. However it's my goal to keep things as simple as possible. My usage is to stack components together to assemble the model much like one would in actuality. Hex nuts, lock washer on threaded rod etc.
              Additionally, there is the self-educational aspect of solving the which selection is on first πŸ˜„ This tool already has four options and looks to acquire one or more in the future. So it seems prudent to solve this now to make ready for the unforeseen. 'Sides any excuse to cut code!!
