    Removal of internal lines generated from raytest
    1 Posts 1 Posters 507 Views 1 Watching
    • H
      hanl000
      I'm currently working on raytest now.
      The main work of this raytest is to generate triangular faces with specific orders of vector and this step is repeated again to get smaller triangles which make higher accuracy.
      I attached a result of the raytest. You can get what I'm saying.
      After making many triangular faces, I was about to merge the internal lines to look at clear face.
      The problem is, there are lines generated on same positions twice by two trials and they are not removed by existing plugins remove internal lines.
      The overlapped lines, I would like to remove these lines on same position with ruby API. How can I do?
      Triangular Faces.skp
