    Script to automate Texturing a surface -> Render
    2 Posts 1 Posters 631 Views 1 Watching
    • C
      Carpeggio
      Hey guys,
      New to Ruby and Sketchup. But making do with what resources I find.
      # Ruby Script for Retexturing and Rendering Scene from source directory images.
      # Have top of board game/material selected (Just the top face) before running script.
      inputDir = Dir.open "C;/Users/XXXX/Downloads/Notes And Things/Photo_Illustrator_OddandEnds/SketchUp/Gameboard Modeling/TopCovers(Bulk)"
      i = 1
      inputDir.each do |file|
      	# Process through Sketchup.
      	# Get a handle to the selection set.
      	currentMaterial = Sketchup.active_model.materials.current
      	currentMaterial.texture = File.absolute_path file
      	UI.messagebox(file)
      	# Save Render to outputDir.
      	view = Sketchup.active_model.active_view
      	view.write_image "C;/Users/XXX/Downloads/Notes And Things/Photo_Illustrator_OddandEnds/SketchUp/Gameboard Modeling/Renders/BulkOutput/testImage#{i}.png"
      	i = i + 1
      It runs, and produces output write_images. However, the material does not update. I cannot for the life of me figure out why.
      Hoping to see these images get placed onto the model;
      http://i.imgur.com/jXTMik5.png
      but in the output I only see the original texture;
      http://i.imgur.com/XNxZpWt.png
      The script requires that you have the material with the texture selected because of the line 'currentMaterial = Sketchup.active_model.materials.current' selects that.
      In 'currentMaterial.texture = File.absolute_path file' I was hoping to find some syntactical error that would lead to nothing being applied, but I'm not seeing anything.
      I'm taking screenshots right now with view.write_image just for proof of concept, but hopefully I'll upgrade that to one of two things;
      Create a scene per texture, then Batch Render with Vray after all the textures have been put into a respective scene. OR... Render between retextures. I'm not sure which can work.
      • C
        Carpeggio
        Here's what my input/output folders look like after the script: http://i.imgur.com/9yTBr90.png
