    Find to which face a door belong
    4 Posts 2 Posters 878 Views 2 Watching
    • M
      MaryamR
      hello everyone,
      i have a model and i need to detect which face contains a door, i managed to detect windows using the outer and inner loops but it doesn't work on doors as the door has an edge that is common between the face and the floor.
      this is the code i use to detect windows and find to which face they belong:
      model = Sketchup.active_model
      ents= model.active_entities
      ents.each do |f|
      if f.is_a? Sketchup;;Face
      inner_loops = (f.loops - [f.outer_loop])
         nested_faces = []
         inner_loops.each{|loop|
        loop.edges[0].faces.each{|e|
           nested_faces << e unless e == f
         if nested_faces.empty?
        UI.messagebox("Face; #{f.material.display_name} has no windows ")
         else
         nested_faces.each{|ff|
      	 UI.messagebox("Face; #{f.material.display_name} contains the window #{ff.material.display_name} ")
      how can i change my code so that it detects doors also ?
      thnx a lot.
      that's the model where i'm testing the doors' detection.
      the model's image
      the model skp file
      • sdmitchS
        sdmitch
        Please update your info to reflect that you are using version 2016.
        If you assume that all walls and doors are vertical and the vertical edges of the door start or end on the bottom edge of the wall then
        ents = model.active_entities
        doors=[]
        ents.grep(Sketchup;;Face).each{|f|
         next unless f.normal.z==0 #vertical faces only
         top=f.bounds.max.z;btm=f.bounds.min.z
         f.edges.each{|e|
          next unless e.line[1].z.abs==1 #vertical edges only
          next unless e.bounds.max.z<top&&e.bounds.min.z==btm
          e.faces.each{|ff|
           next if ff==f || doors.include?(ff)
           UI.messagebox("Face; #{f.material.display_name} contains the Door #{ff.material.display_name} ")
           doors<<ff
        http://sdmitch.blogspot.com/
        • M
          MaryamR
          thnx for your answer.
          there is a cases where a model can contain 2 windows linked to a door like the model below, but it doesn't appear using your code
          data extraction.skp
          • sdmitchS
            sdmitch
            Seems rather odd to have windows connected to a door but then I'm no architect. It finds the door but it also thinks the door is a wall and the wall is a door because it has an edge that fits the door criteria, vertical and shorter than the adjoining face.
            ps. Files posted should be version 8 so that, the unfortunate ones like myself who don't have the latest Sketchup version, can view the model.
