    Geocoder for Sketchup Ruby API
    3 Posts 2 Posters 746 Views 2 Watching
      MaryamR
      hello everyone,
      I'm trying to create a model of a house that exists in real life, and add an inputbox where the user can write the actual address of that house and then show location of that building in Google Maps.
      i tried to install geocoder: Gem.install("geocoder")
      but it doesn't find it:
      Error; #<Gem;;SpecificGemNotFoundException; Could not find a valid gem 'geocoder' (>= 0) locally or in a repository>
      C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/dependency_installer.rb;301;in `find_spec_by_name_and_version'
      C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/dependency_installer.rb;110;in `available_set_for'
      C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/dependency_installer.rb;322;in `install'
      C;/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems.rb;526;in `install'
      <main>;in `<main>'
      SketchUp;1;in `eval'
      does this gem works only for Ruby on Rails and Sinatra .. ? is there another gem like geocoder that is used for the Ruby Sketchup API ?
      thank you a lot.
        driven
        @maryamr said:
        ...the user can write the address of that building and the show the location of that building in Google Maps...
        How does this differ from 'Get Location'?
        why do you need a gem for something that's built into Google Maps?
        john
          MaryamR
          No it's not built inside google map.
          i'm creating a model of a house that exists in real life, ad i write it's address in an inputbox.
          now i want to creat a plugin that shows the location of that house on google map based on the address i wrote .
