    Scrambler issue
    31 Posts 3 Posters 5.2k Views 3 Watching
    • WhyDiW Offline
      WhyDi
      Good Morning,
      We are meeting hard time with the scrambler. Ruby script works well and scrambled on recent Sketchup version as well but crashes or runs bug splat window on older version. We spent much and much time to preserve backward compatibility and now are unable to deliver good code on Sketchup old version due to that scrambler.
      Does anyone hold old version of the scrambler and send us?
      Best Regards
      the devil is in the detail
        I don't think the RBS scrambler has changed since it was first released.
        But there has been some bugs where loading RBS would fail/crash because of too long lines in the source code. I'd start there - check the length of the lines in your RB files.
        Some of the more recent version allowed for longer length's lines, but still have a max limit. (don't recall the exact numbers.)
        • WhyDiW Offline
          WhyDi
          Hi thomthom,
          Bad news! RBS scrambler won't serve our purpose because of line max limit.
          I have now to find out a solution 'by myself' to obfuscate our ruby script but really don't know where to start.
          any help appreciated
          have a good day
            Why can't the lines be broken into smaller ones? You have to have some pretty long lines to trigger this bug - far beyond what is normal for source code. I have some times seem people embed HTML etc as one-liners, though this could easily be extracted as separate resources loaded at runtime.
            What versions of SU are you looking to support? How far back are you going?
            I'm not sure what to recommend as alternatives - depend on how far you feel the need to go. This could easily snowball - which is why I'd recommend looking into breaking up the long lines.
            • WhyDiW Offline
              WhyDi
              Reading your post I feel better as I know there are alternatives even time consuming
              In fact there are so many long lines of code in our script which weights nearly 500k with comments I should add. We knew about some RBS scrambler limits but were far from what you have just told to me.
              On the other hand code obfuscation is not an option but a need.
              We take care to develop under Sketchup8 an test 2013, 14, 15, 16 make or pro version. From where we are now we can't go back. I am fully aware this could easily snowball but want to give a trial to any solution.
              Anyway I don't see any other way right now
                Five hundred thousand character long lines? Did I read that correctly? How do you end up with lines that long? Auto-generated code?
                Is is embedded resources (binary data)?
                If you cannot address the line lengths (I don't fully understand why this wouldn't be possible) then you'd have to find a way to scramble or encrypt your files yourself, have a proxy loader that reads your files and descrabmle/decrypt and then evaluate the code. You can do this as easily as base64 encoding it or as complicated as you want with true encryption etc. You can do the loading and decrypting in a Ruby C extension to hide the loading logic.
                However, I really would recommend focusing on your source code line length. I struggle to see any reason for source code to be more than a couple of hundred characters long - none the less in the thousands!
                Wait.... are you talking about number of lines? Because that'd make more sense. I was talking about number of characters per line.
                • WhyDiW Offline
                  WhyDi
                  You're right I'm talking about numbers of long lines, not a single line of five hundred thousand of chars. But why not? might be a way more to prevent code from being easily read.
                  Scramble or encrypt the script is not the issue and I fully understand your recommendation. I may end up with shortening lines length but would have liked to know more about the process you describe. My understanding is c++ reads and unscramble my data file then sends the result -which is a ruby script- straightforward to Sketchup. Am I right?
                  If so where can I find information about such process ? may you help me to go through?
                    This would be a rare thing to do. I know of only one or two that do the base64 hashing, and one other developer that use their own. But none have fully described in detail the process.
                    I also have no specific encryption method to recommend because I've never had the need to do this.
                    I did debug this issue at some point, and I ran a script on the extension source that basically went through line by line and counted the size. In the two cases I had there where at max 5 lines that exceeded the limit - and they where all due to embedding binary or HTML data. I'd urge you to first do this simple assessment of your source. If it's only a handful of lines then that's so much easier to fix than rolling your own obfuscating system.
                    Another caveat with rolling your own obfuscating system is that you'd make debugging a nightmare for yourself.
                    • WhyDiW Offline
                      WhyDi
                      Hi thomthom,
                      I agree with you but really meet hard time with that scrambler. have a look. The following code crashes on SU8 8.0.14346 but works well on 2016.
                      mainFile.rb
                      require 'sketchup.rb'
                      module Cie_qwerty
                      	module Ext_azerty
                      		#load "C;/Users/uName/SketchUp/Ruby/test.rb"
                      		Sketchup;;load "C;/Users/uName/SketchUp/Ruby/testSC"
                      		puts "------------------------------------------start"
                      		print_test()
                      		puts "------------------------------------------ready"
                      test.rb
                      require 'sketchup'
                      module Cie_qwerty
                      	module Ext_azerty
                      		def self.print_test()
                      			puts "print test"
                      then wScrambler.exe test.rb
                      then rename test.rbs testSC.rbs
                      Sketchup::load or Sketchup::require doesn't matter
                      testSC.rbs or testSC doesn't matter
                      FIRST... load "C:/Users/NeW/SketchUp/Ruby/test.rb"
                      load SU8 : run correctly
                      load SU2016 : run correctly
                      SECOND... Sketchup::load "C:/Users/NeW/SketchUp/Ruby/testSC"
                      Unload then reload SU8: crash
                      Unload then reload SU2016 : works well
                      Ruby console results
                      SU8 one single line and crash. nothing more
                      SU2016 all right
                      print test
                      So what is wrong in my code?
                      have a good day
                        Hm....
                        That is strange.
                        However, I do not see a crash in SU8. I get a Ruby error - but not crash.
                        require 'C;/Users/tthomas2/Desktop/scram/main.rb'
                        Error; #<NoMethodError; undefined method `print_test' for Cie_qwerty;;Ext_azerty;Module>
                        (eval)
                        (eval);0;in `require'
                        (eval);0
                        However, I realize this is due to a bug in older SketchUp where Sketchup.require (Sketchup.load is an alias) will evaluate the content of the file directly into the current namespace.
                        So in your code you ended up with something like this:
                        module Cie_qwerty
                         module Ext_azerty
                          module Cie_qwerty
                           module Ext_azerty
                             def print_test
                        The workaround is to ensure that you do all require outside your namespace:
                        Sketchup;;require "C;/Users/uName/SketchUp/Ruby/testSC"
                        module Cie_qwerty
                           module Ext_azerty
                              print_test()
                        This made the file load correctly for me.
                        Btw, I never saw a crash - did you mean Ruby errors? Quite a significant different - a crash is when the application terminate (with SketchUp you get a BugSplat dialog).
                        • WhyDiW Offline
                          WhyDi
                          No crash your way and no error shown. the script stops and nothing. The bug splat window appears when I run the full script of our extension.
                          I modified the code but get the same result. what sub version of SU8 do you run?
                            When you load main.rb - do you use require or Sketchup.require. The former will yield an Ruby error. The latter will just return false.
                            Have you submitted this crash? (If so entered any info?)
                            8.0.16846
                            Can you share the RBS you generated from that snippet above?
                            main.zip
                            Here's my test files. The path is hard coded to my machine so you'd have to update that to test.
                              My version is the latest SU8 release - meaning Trimble branded.
                              Sketchup.require is the same as Sketchup::require. Just different Ruby syntax.
                              Please submit the bugsplat with some info that can be used to look it up. Like mention it is related to Sketchup.require.
                              • WhyDiW Offline
                                WhyDi
                                Your version is near mine. Does it come from Trimble or Google? Google I think.
                                I use Sketchup::require, not Sketchup.require
                                I haven't submitted the crash yet and don't think I do. It looks so strange!
                                Edit...
                                from your code i modified this way the main file
                                module Cie_qwerty
                                	module Ext_azerty
                                		print_test()
                                This time it works!
                                Sketchup::require or Sketchup.require doesn't matter
                                keepgoing tests...
                                Here are the files not modified
                                test.zip
                                  Here are the files
                                  I did not see a crash when loading your files.
                                  But I did get a load error, you where still having the Sketchup::require statement within your module:
                                  Move it to the global namespace, like so:
                                  Then it loads fine.
                                  • WhyDiW Offline
                                    WhyDi
                                    I edited my previous post with result after reading your code. It works!
                                    Sketchup::require needs to appear before any module.
                                    I go ahead testing line length...
                                      At least in SketchUp versions earlier than SU2014. From then on it was fixed.
                                      • WhyDiW Offline
                                        WhyDi
                                        I found information about line length here
                                        https://groups.google.com/forum/#!topic/sketchupruby/EV5KDgh6C0M
                                        where ChuckVali in the last post wrote :
                                        ...I noticed something else about the scrambler. If there are more than around 1000 characters in any line the resulting .rbs file can't be read by SU. Not a problem though: I just use shorter lines and concat them...
                                        the longest line in our script is over 1500 chars and I won't be able to cut these lines under 503 chars due to if statement with and and and and and so forth.
                                        Are 512 chars OK?
                                        in the same thread I read something that I don't clearly understand. Jim wrote :
                                        ...This may be related to a bug when scrambling Ruby files. If you are
                                        loading the .rbs from a SketchupExtension, the loaded files may be put
                                        under the SketchupExtension namespace. Maybe there are conflicting
                                        names if these other plugins are also loading scrambled files using
                                        SketchupExtension...
                                        Is it what we have just done ? I believe but who knows
                                          driven
                                          @whydi said:
                                          ...I won't be able to cut these lines under 503 chars due to if statement with and and and and and so forth....
                                          the ruby 'style guide' recommends 70 chars per line, so 503 is a'little' longer than that...
                                          you can break **and, &&, or, ||** in statements by escaping a newline...
                                          I leave a space so before the escape \ as I find it easier to read...
                                          if (Sketchup.active_model.tools.active_tool_name == 'ScaleTool' || \
                                             Sketchup.active_model.tools.active_tool_name == 'CameraOrbitTool' || \
                                             Sketchup.active_model.tools.active_tool_name == 'MoveTool' || \
                                             Sketchup.active_model.tools.active_tool_name == 'RotateTool' )
                                             p "waiting for #{Sketchup.active_model.tools.active_tool_name}"
                                          else
                                             # whatever
                                          john
                                          • WhyDiW Offline
                                            WhyDi
                                            Hi driven
                                            70 chars per line are very small but I'm making my best for reducing more an more. Fortunately we are speaking about Sketchup Scrambler not ruby. Using your way I think a might be able to decrease the numbers of characters per line down to 250 even 125 but no more.
                                            Result in some hours...
                                            Have a good day
                                            • 1 / 2
