    SketchyPhysics help2
    3 Posts 2 Posters 7.5k Views 2 Watching
      Mrtapo8
      Hey dear sketchup users,
      i just have one quuestion, how to connect motors or servos to any keyboard key.
        Mrtapo8
        I found this tutorial
        There is very simple to do that!
        Open the servo "UI" and insert " rightx " (no quotes) in the controller field.
        If you want to control the speed (a motor) with up and down arrow, just write " righty " (no quotes).
        But i dont understand how to change keys it is that possible ?
          dgimagge
          Hi everyone, I am new in SketchyPhysics.
          I installed SketchyPhysics in Sketchup 8 (Windows 32 bits).
          I follow the tutorials but at the first test I found an error that has me stopped:
          I create a box and another copy over that.
          Mark "static" to the bottom box.
          Put a hinge in one border (left or right) in the middle edge of both boxes.
          Joint the hinge with the bottom box.
          Group the upper box with the hinge.
          And when I click in "play", the upper box fall down rotating from the hinge and fall through the bottom box.
          I tried to do a lot of times and always the same result.
          Is like that when I assign the "parent" to the hinge to rotate, that parent box become NO solid.
          Help please. Thanks.
