    Surface area of a component/group made up of groups
    2 Posts 2 Posters 707 Views 2 Watching
    • W
      wawmsey7
      I want to get the total external surface area of a component or group that is made up of groups and components that are butted next to each other. So in effect the total surface area of the outer shell of the component not just the surface area of each of the groups/components added together. I appreciate that I could actually 'outer shell' the component and then just get the area of all the resultant faces and add them up - this would work but would slow down the process considerably when working with lots of parts.
      Is there a way of doing this without actually changing the model at all and therefore that doesn't slow down the process too much or does it all start to get quite complex?
      • JQLJ
        JQL
        Fredo has a plugin for area labelling under his Fredo tools. It works rather well and probably the functionallity can be adapted to your needs.
        Sketchup also has the ability to report material areas, so if your outer shell is all made from certain materials you can add up your areas.
        www.casca.pt
        Visit us on facebook!
