    Simple question: Click to create a point
    3 Posts 2 Posters 700 Views 2 Watching
      bardlind
      Long time lurker and Sketchup user, first time poster. Hello!
      I have finally gotten around to creating a little extension for Sketchup, which I will post later on. This is my first time coding in Ruby (and one of my first times coding, ever).
      In the beginning of my script, I create two concentric circles which the rest of the code is based upon. For now, I have just entered the [x, y, z] coordinate for the center point manually. However, I would like to be able to do this:
      Draw a line in Sketchup. Then select my tool from the extensions menu. Click the end of the line I just drew, and this point's xyz is used in my script as the center point.
      I realize this is probably the simplest part of my script, but I have not been able to figure it out. Help is appreciated πŸ˜„
      • sdmitchS Offline
        sdmitch
        Your plugin must be an interactive tool like this
        # Permission to use, copy, modify, and distribute this software for
        # any purpose and without fee is hereby granted.
        # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING,
        # WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
        #    Name;	Add Circles
        #      By;	Bardlind
        #   Usage;	Plugins>Add Circles
        require 'Sketchup'
        unless file_loaded?(__FILE__)
        	UI.menu("Plugins").add_item("Add Circles") { Sketchup.active_model.select_tool Bardlind;;Add_Circles.new }
        	file_loaded(__FILE__)
        module Bardlind
        	class Add_Circles
        		def initialize
        			@mod=Sketchup.active_model
        			@ent=@mod.active_entities
        			@sel=@mod.selection
        			@ip=Sketchup;;InputPoint.new
        			@status_text = "Pick End Point"
        		def onMouseMove(flags, x, y, view)
        			@ip.pick view,x,y; view.tooltip = @ip.tooltip; view.refresh
        			Sketchup;;set_status_text @status_text,SB_PROMPT
        			Sketchup;;set_status_text "", SB_VCB_LABEL
        			Sketchup;;set_status_text "", SB_VCB_VALUE
        		def onLButtonDown(flags, x, y, view)
        			if @ip.vertex
        				@rad1 ||= 10; @rad2 ||= 20; @sides ||= 24
        				values = UI.inputbox(["Radius1;","Radius2;","No. Sides;"],[@rad1,@rad2,@sides],"Add Circles")
        				if values
        					@rad1,@rad2,@sides=values
        					@mod.start_operation "Add Circles"
        					@ent.add_circle(@ip.position,Z_AXIS,@rad1,@sides)
        					@ent.add_circle(@ip.position,Z_AXIS,@rad2,@sides)
        					@mod.commit_operation
        				else
        					onCancel(flags,view)
        			else
        				UI.beep
        		def onCancel(flags,view)
        			Sketchup.send_action "selectSelectionTool;"
        		def draw(view)
        			if( @ip.valid? && @ip.display? )
        				@ip.draw(view)
        http://sdmitch.blogspot.com/
          bardlind
          Thanks alot! I will give it a try.
