    [Solved] Move along Normal
    24 Posts 6 Posters 1.6k Views 6 Watching
      driven
      but HOW are you switching them, you have no Layers, only a single Group and the same Material with both?
      are you doing that outside of SU after this is done?
      • deaneauD Offline
        deaneau
        @driven
        the game switch this.
        in sketchup i build the day and night mesh insert this in a game and the game doing this..
        this look like the churches
        MADE, BORN AND LIVING IN BERLIN
        Big Thank You to all Programmers
        Some German words are so long that they have a perspective. M.Twain
          driven
          given your current workflow, adding code into frontface can work like this...
          I set at 10mm and add a different material for 'select by color' grouping...
          would this work for you?
          at 10mm blue glass...
          • deaneauD Offline
            deaneau
            hey cool this cold be a solution. question is, is this than a new object group? when not its better the plugin-in generate a new color what i have never had before. so i can choose this new generated polys by material and group this.
            in your animation i cant see how it work for frontside polys (white).
            • 2 / 2
