    Detect object intersect
    1 Posts 1 Posters 489 Views 1 Watching
    • C
      CEIT81729
      Hello everyone
      mod = Sketchup.active_model
      ent = mod.entities
      grp = ent.grep(Sketchup::ComponentInstance)
      for i in 0...grp.length - 1
      grp.each{ |g| next if g == grp[i]
      bb = Geom::BoundingBox.new.add(g.bounds.intersect(grp[i].bounds))
      if bb.valid?
      puts "#{g.name.to_s} and #{grp[i].name.to_s} intersect"
      else
      puts "#{g.name.to_s} and #{grp[i].name.to_s} do not intersect"
      bb.clear
      I want to know how to calculate the model of dynamic properties of all objects (such as "Lenx", "Leny" ,"Lenz"...etc) after the object intersected the other object.
      The case description like this:
      First, detect all objects intersect situations like the above code
      Second, if name = "column" objects intersect name = "beam" objects(just a simple example)
      then, "column" objects dynamic properties("Lenx") deduction "beam" objects dynamic properties("Leny")
      Thank you for your advice and help πŸ‘
      Collision detection
      Objects dynamic properties
