    Apply changes when click on the element
    1 Posts 1 Posters 361 Views 1 Watching
    • kimpastroK
      kimpastro
      Hello guys, need some help again.
      Scenario:
      Have two entities selected, and when I click in my plugin need to calculate the sum of both selected LenX and apply this value on the next entity that i'll click. Like image below:
      http://imageshack.com/a/img538/3996/y8E0rI.jpg
      My code until now:
      model = Sketchup.active_model
      selections = model.selection
      lenx_total = 0.to_i
      leny_total = 0.to_i
      lenz_total = 0.to_i
      if selections.empty?
        UI.messagebox('Select at least one component.')
      else
          selections.each do |sel|
            lenx_total = lenx_total + sel.definition.get_attribute('dynamic_attributes', '_lenx_nominal')
      # All this is for test only, where i'm stuck and trying to discover something
      model.find_entity_by_id(18618).definition.set_attribute 'dynamic_attributes', '_lenx_nominal', lenx_total
      new_def = model.find_entity_by_id(18618).definition
      model.place_component new_def
      Thanks for your time.
