    Which folders does SU look for gems in?
    3 Posts 2 Posters 801 Views 2 Watching
      sepultribe
      Gem;;default_dir
      C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/lib/ruby/gems/2.0.0
      Gem;;user_dir
      C;/Users/Popi/.gem/ruby/2.0.0
      Gem;;dir
      C;/Users/Popi/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Gems
      Let's say someone needs to install some gems on a pc with no internet con. In which of the above folders must one place the gem files? Will it also need the spec files too? Or anything else?
      • Dan RathbunD Offline
        Dan Rathbun
        @sepultribe said:
        Gem;;default_dir
        > Gem;;user_dir
        > Gem;;dir
        FYI the first two paths are totally incorrect, as I had told you in another thread, the SketchUp Team has not yet provided a rubygems defaults override rb script (as outlined in the comments at the top of the "rubygems.rb" file.)
        Therefore, the paths returned by most Gem class methods will be invalid.
        BUT,... the SketchUp Ruby C-side initialization routine DOES set two environment variables:
        ENV["GEM_HOME"] and ENV["GEM_PATH"]
        which are both the same, but DO DIFFER with bitness on SketchUp 2015 & higher:
        SketchUp 2014
        ENV["AppData"] + %(#800080)["/SketchUp/SketchUp 2014/SketchUp/Gems"]
        SketchUp 2015 64-bit
        ENV["AppData"] + %(#800080)["/SketchUp/SketchUp 2015/SketchUp/Gems64"]
        Actually none of the above.
        The Gem::install method will check the "cache" sub-directory of the ENV["GEM_HOME"] path for the gem archive, if it is not there, it will try to download it from the gemserver.
        You can use the Gem::install class method, OR create your own installer instance, with custom options, by calling Gem::Installer::new
        The specification file is inside the gem archive file. It will be copied to the
        "#{ENV['GEM_HOME']}/specifications"
        sub-folder by the Gem::Installer instance that is installing the gem.
        The complete online Rubygems documentation is here:
        http://ruby-doc.org/stdlib-2.0.0/libdoc/rubygems/rdoc/index.html
        I'm not here much anymore.
          sepultribe
          Thanks, I will test this and come back to post the results.
