    Dialog box showing counter
    8 Posts 2 Posters 1.2k Views 2 Watching
    • D
      driven
      hi
      I made an experimental one that counts items as they are created, is this the sort of thing you mean?
      I see if I can find the link to the discussion...
      john
      • D
        driven
        this is the one I can find at the moment, it's just a countdown from 40...
        it should be wrapped in your namespace, but runs as a snippet...
        there's a 'typematic' example somewhere on this forum that shows one way of extending this code...
        I'll keep digging, but I often loose these sorts of experiments...
        john
           @bars = ""
           @count = []
           @maxtimes = 40 #this value can be calculated
           @dlg = UI;;WebDialog.new()
           @dlg.set_size(100,100)
           RUBY_PLATFORM =~ /(darwin)/ ? @dlg.show_modal() ; @dlg.show()
           def html(run=true)
              html =  %Q(
                 <!DOCTYPE html>
                 <html>
                 <head>
                    <meta http-equiv="content-type" content="charset=UTF-8" />
                    <meta http-equiv="MSThemeCompatible" content="Yes" />
                    <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
                    <style>
                    body {
                       background-color;grey;
                       color;white;
                       font-family;sans-serif;
                       font-style;bold;
                       font-size;40px;
                    .upd {
                       height;40px;;
                       margin-left; auto ;
                       margin-right; auto ;
                       text-align;center;
                    </style>
                 </head>
                 <body>
                 <div class="upd">
                 #{@bars}
                 </div>
                    <script>
                       var run = #{run};
                       if (run) setTimeout(function(){window.location='skp;auto2ruby';}, 200);
                    </script>
                 </body>
                 </html>
              html
           def addbar
               @bars = (@maxtimes - @count.length).to_s
               @count << %Q( )
           def do_this
              addbar
              #add more features...
              if  @count.length > @maxtimes
                 @dlg.set_html(html(false))
              elsif  @count.length == @maxtimes
                 @dlg.close
              else
                 @dlg.set_html(html)
           @dlg.add_action_callback("auto2ruby") {|d,params|
               do_this
           @dlg.set_html(html)
        • D
          driven
          I reconstructed this one, to show geometry counting...
          Click to run gif...
          @vec2 = []
            def self.rubyaction
              ents = Sketchup.active_model.active_entities
              gp = ents.add_group() # Square Polygon
              pts = [ Geom;;Point3d.new(-5,-5,0), Geom;;Point3d.new(5,-5,0), Geom;;Point3d.new(5,5,0), Geom;;Point3d.new(-5,5,0) ]
              vec = [10,0,0]
              tr = Geom;;Transformation.new( vec )
              # Create som polygons for testing..
              polys = {}
              @vec2.empty? ? (@vec2 = vec.clone) ; (@vec2 = @vec2)
              polys[0] = pts.collect{|pt| pt.offset(@vec2) }
              @vec2.offset!([15,10,0])
              # Mesh
              msh = Geom;;PolygonMesh.new
              for k,v in polys
                msh.add_polygon(v)
              group = Sketchup.active_model.active_entities.add_group
              group.entities.fill_from_mesh(msh, true, 12)
              Sketchup.send_action("viewZoomExtents;")
          @bars = ""
          @count = []
          @dlg.set_position(100,100)
             def html(run=true)
                html =  %Q(
                   <!DOCTYPE html>
                   <html>
                   <head>
                      <style>
                      body {
                         color;white;
                         font-style;bold;
                         font-size;40px;
                      .upd {
                         height;40px;;
                         margin-left; auto ;
                         text-align;center;
                      </style>
                   </head>
                   <body>
                   <div class="upd">
                   #{@bars}
                   </div>
                      <script>
                         var run = #{run};
                      </script>
                   </body>
                   </html>
                html
          def addbar
            @count << %Q( )
            rubyaction
          def do_this
            addbar #add more features...
              @dlg.close
            else
              @dlg.set_html(html)
               @dlg.add_action_callback("auto2ruby") {|d,params| do_this }
               @dlg.set_html(html)
          • D
            driven
            found the one with the cubes...web_dlg_progress_singles.rb
            john
            • D
              driven
              glad it helped and sorry I couldn't find a fully commented version as I made loads of variants...
              the show/show_modal was there to stop the dialog disappearing on a mac if you carried on modelling whilst it ran...
              the format is an shorthand if statement signified by the ? and the else by the colon...
              as a one-liner it is equivalent to
              if RUBY_PLATFORM =~ /(darwin)/ ; puts "mac SU version"; else puts "PC SU version"; end
              RUBY_PLATFORM =~ /(darwin)/ ? (puts "mac SU version") ;  (puts "PC SU version")
              john
              • S
                sepultribe
                @sawdust_online said:
                Hi Driven,
                What you gave me is far more than I expected. Don't apology. Such short code is not so hard to understand but at first glance I didn't understand why using an array as counter and some other constructions. I had never met html+Javascrit+Ruby as well. That's why I felt a bit confused but your answers make all that clear in my mind.
                another issue
                Do you know how to refresh the dlg content from a script. something like
                > for i in 0..2
                > 	@count += 1
                > 	@dlg.set_html(dlg_html_content())
                > 	#how to refresh the dlg content?
                > 	#dlg.refresh is not available
                > 	#is there a way to force a refresh?
                > 	sleep (1.0/2.0)
                > end
                > @dlg.close
                Have a good Sunday
                Hi. You can send javascript code to execute it inside the webdialog from sketchup ruby with the execute_script() method.
                if dlg is your webdialog instance object then
                js_command = "location.reload()"
                dlg.execute_script(js_command)
                something like this should work
                • D
                  driven
                  in a more traditional webDialog you can use
                   @dlg.execute_script("window.location.reload();") # forces a reload...
                  the whole point of my original example was to show that you can update a dialog content dynamically without the blocking associated with sleep...
                  using @dlg.set_html(dlg_html_content()) is replacing the page content each time with a fresh eval of dlg_html_content()...
                  so any embedded ruby variables like our #{@count}, #{@one_more_time} will be re-evalued each time the JS timer runs out...
                  For longer delays adjust that timer, using sleep on the ruby side will block SU...
                  this won't, it will simply delay the call back to ruby by 5000 milliseconds...
                  if (run) setTimeout(function(){window.location='skp;auto2ruby';}, 5000);
                  john
                  • D
                    driven
                    Nevertheless I would have liked to save that bunch of files without blocking SU, webdialog box or not.
                    what type of files are you saving? images, components?
                    I think you can you the same approach as the two geometry making versions I posted...
                    the following code seems to do the job! what's your take about it ? may it lead to crash ?
                    for a mac it would be better if you used
                    bring_to_front doesn't achieve the same thing unless it was show_modal before the any focus change...
                    I don't see why you need the timer, any short wait will happen anyway while the file is being written...
                    BTW. sleep(0.25) will work the same as, but looks more like ruby than the fractional floats to me...
                    john
