    Return values from ruby system calls
    3 Posts 3 Posters 674 Views 3 Watching
      Lance_Uppercut
      This should be really simple, but for some reason I cannot get any return values from simple Ruby system calls from within Sketchup...for example:
      puts `echo test`      # nil result
      x = `echo test`       # nil result
      puts x                # nil result
      x.empty?              # true
      system('echo test')   # true
      Strangely the system('echo test') returns true, indicating that the process was successfully run...does anyone have any ideas? I'd like to avoid having to use txt or csv files as intermediaries.
      Thanks,
      Sebastian
        driven
        v8 users the really old ruby version...
        so try "test" for your string
        and also try x = %x(echo "test")
        • Dan RathbunD Offline
          Dan Rathbun
          SketchUp 2014 was bugged in this regard. The workaround was to pipe to a text file, I think.
          I think it was fixed in SketchUp 2015.
          I recall having written a patch script that overrode the Kernel.backquote method. (I have to have a look for it.)
          I'm not here much anymore.
