    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Multiple Sketchup Versions or Installations?
    3 Posts 3 Posters 7.2k Views 3 Watching
      jzslik
      I have been using SU 8 with Sketchy Physics 3.2 and many other plug-ins for years.
      I want to begin using SU Make & Possibly SU Pro.
      If I upgrade to either of those, can I open or import my SU 8 models to the newer version(s), and will the models retain their integrity with regards to modification, manipulation, updating, or Sketchy Physics?
      It seems insurmountable to have to redo all of my models just to move to the current SU ver.
      If this subject has already been addressed somewhere within the forum, I offer my apologies.
      My sincere thanks in advance to any who can help to shed accurate light on these questions.
      • cottyC Offline
        cotty
        You can install different versions (8, 2014, ...) at the same time.
        Sketchyphysics only works with 32bit versions, if you use 2015 64bit, you cannot use it.
        You can always open older files in newer versions (and save in older format in newer versions).
        my SketchUp gallery
        • KrisidiousK Offline
          Krisidious
          I have 2013, 2014 and 2015 Pro installed. getting ready to uninstall 13 & 14 because I never use them... I kept each as a precaution when install the newer versions.
          By: Kristoff Rand
