    Make SketchUp API to recognize System PATH
    3 Posts 2 Posters 638 Views 2 Watching
    • G Offline
      gmolina1
      Hello everyone,
      I have been developing a SketchUp extension for a while, but I am not really a programmer... please be patient, haha. I am trying to call Radiance, a lighting analysis toolbox... its calculations take a while, and the programs are meant to be run in the terminal. My idea is to create some scripts for enabling the non-expert users to perform simulations.
      As a start, I managed make systems calls using "popen3", which allow me to diference the stout from the stderr, etc. That is cool.
      The problem now is that the programs in my PATH are not recognized. I tried to write the whole directory, but some of the programs call, internally, more programs... so I get the "program not found" (does not say exactly that) error.
      Is there any way of telling SketchUp too register some directories as part of the PATH? As a second option, I thought on creating a JAVA app that is opened from SketchUp to manage the simulations? Is this possible/advisable? Whould the same happen here? A JAVA app would actually give me the advantage of porting it to Linux, where calculations take shorter times (bigger computers, haha).
      Another fact to consider is that I do not want SketchUp to be paralized while calculating.
      There are a few things to consider in the blender... if you could help me with the mess in my head, it would be awesome.
      Best,
      • Dan RathbunD Offline
        Dan Rathbun
        (1) Variables like the %(#8000FF)[PATH] are part of the system Environment. From a system shell you access them using % delimiters, like so: %(#8000FF)[%PATH%]. You can list them all using the %(#8000FF)[set] command.
        (2) Each application than runs, gets a COPY of the Environment (variables) so that if other programs change them, then it will not effect all programs.
        So.. this leads to your question ...
        Inside SketchUp, you can access, change and add variables of SketchUp's copy of the environment, via the Hash-like construct ENV.
        To list it, load Pretty Print:
        require "pp"
        Then "pp" the ENV hash in the Console:
        pp ENV
        But be aware that inspect and pp both escape back-slash characters in their output. (The Strings do not really have doubled back-slashes.)
        So you can convert these to Ruby/Unix-like path strings:
        path = ENV["PATH"].gsub(/\\\\|\\/,'/')
        You can add a helper method in your plugin module, like:
        def rubyize_path(p)
          p.gsub(/\\\\|\\/,'/')
        SO...
        progpath = rubyize_path(ENV["ProgramFiles"]) old_path = ENV["PATH"] ENV["PATH"]= "#{progpath}/some/extra/new/path;" << old_path
        When your done, reset ENV["PATH"], thus:
        ENV["PATH"]= old_path
        But changing the SketchUp ENV["PATH"] variable, only affects things that run from SketchUp's process. Shell scripts may not be able to see it. SO TEST, & test again.
        (3) Temporarily changing the working directory.
        work_dir = rubyize_path(ENV["ProgramFiles"]) << "/Radiance"
        Dir;;chdir(work_dir) {
          # Things to do in the work dir
        # The previous directory (whatever it is...)
        #   is automatically restored outside the block !
        (4) Executing shell commands.
        The %x construct can execute shell commands with cmd.exe on Windows.
        You may use ANY delimiter character (or matched bracket or brace characters.)
        ver_text = %x{ver} pp ver_txt
        I chose curly braces, but you could use dollar signs, or square brackets, whatever.
        That should give some food for thought.
        I'm not here much anymore.
        • G Offline
          gmolina1
          Thanks, Dan! Your answer does give A LOT of food for thought. I will try someof these and let you know.
          Regards
