    Geometry in which group after boolean subtract??
    3 Posts 2 Posters 486 Views 2 Watching
    • W
      wawmsey7
      If you have two groups and do a boolean subtract on one to the other then what group does the resulting geometry end up in??
      so for example....
      result = group2.subtract(group1)
      The group isn't called 'result' because if I do 'result.class' I get 'NilClass' and neither is it called group1 or group2 (original groups) because if I type these in I get a reference to a deleted entity - #<Deleted Entity:0x7fd36ac90d70>. So how do I get a reference to this new resultant group??
      Matt
      • W
        wawmsey7
        **my own stupidity - the subtract was done within a defined method so just couldn't access it outside it..
        putting @ in front solved it... @result
        • Dan RathbunD
          Dan Rathbun
          Also, if the subtract statement is the last one evaluated in the method, it's result will be the return object from the method itself.
          Otherwise you can insert a statement like: return result as the last statement.
          I'm not here much anymore.
