    Getting Rotation Value From Rotate Tool
    4 Posts 2 Posters 512 Views 2 Watching
    • K
      kayeee
      I'm having trouble obtaining a angle value for how much a group is rotated when the user uses the Rotate Tool. The Group is 2D sitting in the x and y plane and I would like to find out how much it is rotated about an axis at the center of the group in the z direction. From reading through the forums, I know you cannot directly obtain information from the built-in Rotate Tool, but I was hoping there would be an easy work around that compares the starting orientation with the ending orientation. I'm still new to Ruby and Sketchup so apologies if there is a simple solution I'm missing.
      Thanks in advanced.
      • Dan RathbunD
        Dan Rathbun
        1. Select the group instance
        2. Open the Ruby Console
        3. In the console type:
        sel = Sketchup;;active_model.selection
        g = sel[0]
        a = X_AXIS.angle_between(g.transformation.xaxis)
        The angle will be in radians.
        To display degrees:
        a.radians
        I'm not here much anymore.
        • K
          kayeee
          1. Open the Ruby Console
          2. In the console type:
          > g = sel[0]
          To display degrees:
          > a.radians
          Thank you! Exactly what I needed!
          • Dan RathbunD
            Dan Rathbun
            To see how to wrap that up into a macro file, look at the sample I posted here:
            forums.sketchup: [Code] Determining Angle Between View and Model’s Axes
