    Add_face from edges??
    8 Posts 3 Posters 963 Views 3 Watching
    • W
      wawmsey7
      Hi, I'm pretty new to ruby coding in sketchup so i'm just trying to get my head around a few bits of basic code. I'm trying to make a face from two straight edges and a curve.... the edges are drawing fine but i'm getting an error when I try to make a face from the edges??
      this is my code atm...
      %(#004080)[radius =10
      startangle =90.degrees
      endangle =0.degrees
      centerpoint = Geom::Point3d.new
      vector = [0,0,1]
      vector2 = [1,0,0]
      vector3 = vector.normalize!
      model = Sketchup.active_model
      entities = model.active_entities
      curve = entities.add_arc centerpoint, vector2, vector3, radius, endangle, startangle
      edge1 = entities.add_edges [0,0,0],[0,radius,0]
      edge2 = entities.add_edges [0,0,0], [radius,0,0]
      face = entities.add_face (edge1,curve,edge2)]
      In the API documentation it says I should be able to make a face from a bunch of edges...
      %(#0000BF)[entities.add_face(edge1, edge2, edge3, ...)
      entities.add_face(edgearray)
      entities.add_face(pt1, pt2, pt3, ...)
      entities.add_face([pt1, pt2, pt3,...])
      entities.add_face(curve)]
      Does anyone know why this won't work?
      Thanks in advance
      Matt
      • sdmitchS
        sdmitch
        %(#004080)[
        radius =10
        > endangle =0.degrees
        > centerpoint = Geom;;Point3d.new
        >  vector =  [0,0,1]
        >  vector2 =  [1,0,0]
        Thanks in advance
        Matt
        The problem is that you have a mixture of edges and an edge array. It will work if you combine them into a single array
        face = entities.add_face (edge1+curve+edge2)
        For future reference, always use a code block to simplify the selecting and copying.
        http://sdmitch.blogspot.com/
        • W
          wawmsey7
          thanks for your quick response, that worked perfectly!
          • Dan RathbunD
            Dan Rathbun
            You should also be able to use Ruby's parameter expansion operator *.
            It expands arrays into parameter lists:
            face = entities.add_face(edge1,*curve,edge2)
            Also, do not put a space between the method name and the opening parenthesis when making method calls. (Ruby 2.0 will generate an error, whereas Ruby 1.8 just spit out a warning.)
            I'm not here much anymore.
            • W
              wawmsey7
              Thanks.
              Just another quick one...
              I'm also struggling to make a simple rotation on an edge
              my code atm is...
              edge1 = entities.add_edges [0,0,0], [0,10,0]
              tr = Geom;;Transformation.rotation([0,0,0],[0,1,0],40.degrees)
              edge1.transform!(tr)
              again the edge draws fine but my rotation code throws up an error!
              anyone got any ideas?
              Thanks again
              Matt
              • sdmitchS
                sdmitch
                @wawmsey7 said:
                Thanks.
                my code atm is...
                Thanks again
                Matt
                rotation of an edge on the Y axis around the Y axis makes no sense.
                .transform! is for groups,components,vectors,points,etc. but not edges.
                #tr = Geom;;Transformation.rotation([0,0,0],[0,1,0],40.degrees)#rotation around Y axis?
                tr = Geom;;Transformation.rotation([0,0,0],[0,0,1],40.degrees)
                #edge1.transform!(tr)#transform! not allowed for edge.
                entities.transform_entities(tr,edge1)
                • W
                  wawmsey7
                  thanks again for your help - that makes a lot more sense!
                  • Dan RathbunD
                    Dan Rathbun
                    Matt, have the Ruby Console open when testing code, and paste the error message in the post, if your asking about Ruby errors.
                    The first error message line in the backtrace will contain a sub-string like:
                    “filename:lineNo: inmethod'”or “filename:lineNo.”`
                    which tells you exactly what ruby script, it's line number, and possibly the method that it occurred within.
                    The message tells you (usually) exactly what went wrong.
                    For example,
                    Error: #<NoMethodError: undefined methodtransform!' for #Sketchup::Edge:0x00000009e8e690>... tells you that the Sketchup::Edge class has no instance method named " transform!`".
                    So at that point your quickest way to resolve your dilemma, is to go to the API's Method index, and find methods in the "T" category that have to do with transformations.
                    See Exception class, backtrace() method.
                    And more generally dealing with exceptions.
