House Builder Plugin
I have found a calculation error in the floor joist, wall stud, and roof rafter spacing in the House Builder plugin
I build houses with Habitat for Humanity and wanted an easy to use tool to model our house plans in SketchUp. I found House Builder. It is a good basic tool.
As I was entering our current floor plan I noticed that my 4'x 8' sheet goods were not landing at the center of floor joists, wall studs, and roof rafters. I looked closer and discovered that the spacing between the first and second objects was off by 3/4". The tools use the entered On-Center spacing for all objects...not good when building a structure.
I've emailed the maker of House Builder and am waiting to hear from them.
This will be an excellent tool if they address the calculation error.
I'm posting here because I see that there are other House Builder posts on this site.
George -
Maybe some images and files will be avoid missunderstanding!
Ganderson - I have noticed the same thing, all studs are spaced at 1' 4" from the outer edges which of course is wrong. I posted such here a while back but never got anything back on it. Perhaps HouseBuilder was meant as a simple tool to estimate materials and get an idea of what the finished project looks like, because anyone using it as drawings to build by are in for a rude awakening when they go to install their sheet products. Unless I'm missing something? What I don't understand is why there are not hundreds of posts pertaining to this over the years that HomeBuilder has been out there.
probably a plugin that doesn't get updated but did anyone ever fix this issue? I've been trying to put on plywood and it's not working because it does bad spacing for sheet goods. Anyone find a workaround?
Jay4554@aol.com -
did anyone find the workaround for this extension? the layout is not good for 4x8 plywood sheets
Register LoginAdvertisement
