    How to pick up sheets?
    6 Posts 2 Posters 7.9k Views 2 Watching
      davetsai
      Dear All,
      It is very interesting to use SP and thanks Mr. Phillips for this great plugin.
      As a non-English user and non-programmer, it takes me much time to study.
      I have a situation needs masters like you guys to help.
      Please check the attachment.
      I try to use magnet to pick up the sheet, however the sheets are difficult to be controlled.
      I hope the pad can pick up and put down the sheet, not the sheet moves by itself.
      Can anyone write a script for this situation?
      I will be very appreciated.
      Thank you and best regards,
      Dave Tsai
      pick up sheets
        Anton_S
        Sure! I will!
          Anton_S
          Here you go!
          All objects with the name 'sheet' will be picked. Objects with different name or no name will not be picked.
          I can also make the robo more advanced to stop when there are no sheets, but I wanted to ask you before I proceed.
          pickup sheet.skp
            davetsai
            Anton, You are a genius!
            Thank you for your help!
            It will be great to stop the robot when there is no sheet.
            Thank you again!
              Anton_S
              Done!
              pickup sheet.skp
                davetsai
                Good job! Anton
                Thank you so much!
