    Replace component and set dynamic attributes?
    3 Posts 2 Posters 945 Views 2 Watching
      skavan
      OK - here's the challenge.
      I have a model with several non-dynamic components (doors).
      I have a dynamic component (door) called LDOOR.
      I can select all the non-dynamic components -- and then what I want to do, for each such instance is:
      1. grab the height, width, depth and X,Y,Z, and rotation of the non-dynamic component
      2. assign height, width and depth and X, Y, Z and rotation to attributes: LenX, LenY and LenZ,X,Y,Z,RotX etc.. of the dynamic component.
      3. have the dynamic component update itself (i.e. react to the changes in #2)
      4. replace the non-dynamic component with the new instance of the dynamic component.
      It MUST be possible...and I have carefully studied TIG's component replacer code - but try as I might I can't get it to work.
      So far, I can easily select the dynamic component:
      model = Sketchup.active_model definitions = model.definitions component = definitions['LDOOR']
      and I can happily iterate through my selected "non dynamic components":
      sel=model.selection for instance in sel h= instance.bounds.height d= instance.bounds.depth w= instance.bounds.width x= instance.transformation.origin.x y= instance.transformation.origin.y z= instance.transformation.origin.z r= Math.asin(instance.transformation.to_a[4]).radians.round next
      But how to now create a new instance of the dynamic component and fill in the values!!!! H-E-L-P!
        skavan
        OK - getting close -- very close -- but stuck on getting the right rotation (and I'm sure there's a cleaner way of doing all this):
        The issue is that I'm retrieving the wrong rotation. If I create a rotZ attribute on the entity I'm trying to replace, it shows (for example) 135 degrees. But the instance.transformation array gives me a z-rotation of -45. I'm stumped! I've attached a sample scene. The dynamic door is RED and my targets are, well, not.
        door test scene.skp
        ` model = Sketchup.active_model
        entities = Sketchup.active_model.entities
        model.start_operation("Create Door")
        #create a new instance
        transformation = Geom::Transformation.new([0,0,0])
        componentinstance = entities.add_instance(component, transformation)
        puts 'we have added a new instance (GUID:' + componentinstance.guid + ')'
        $dc_observers.get_latest_class.redraw(componentinstance)
        model.commit_operation
        model.start_operation("XForm Door")
        sel=model.selection
        instance = sel[0]
        d= instance.definition.bounds.height
        h= instance.definition.bounds.depth
        w= instance.definition.bounds.width
        componentinstance.transformation = Geom::Transformation.new([x,y,z])
        d=2 ;#override depth
        #instance.attribute_dictionaries["dynamic_attributes"].each_pair{|k,v|p k;p v;puts}
        ad = componentinstance.attribute_dictionary "dynamic_attributes"
        ad["_lenx_formula"]=w.inspect
        ad["_leny_formula"]=d.inspect
        ad["_lenz_formula"]=h.inspect
        ad["_rotz_formula"]=r.inspect
        entities.erase_entities instance
        • G Offline
          Garry K
          There are a few things that I had to deal with.
          I found it easier to put the dynamic attributes in a nested group as opposed to the outside group. This way you can rotate the entire door and jamb to fit it into the door opening and you don't have to keep changing the dynamic rotz. These doors can be copied, flipped and or rotated while preserving the desired angles of rotation.
          4 doors.skp
