    Save workbook with input box entry
    5 Posts 2 Posters 639 Views 2 Watching
      davesexcel
      Is it possible to saveas a workbook from input box?
      Something like this is what I'm trying to do.
      	prompts = ["Top Hanger Thickness","Customer Address"]
          defaults = [3.0, "Howdy"]
          input = UI.inputbox prompts, defaults, "Stair Info"
              a,b=input
            require('win32ole')
         excel = WIN32OLE.new('Excel.Application')
         excel.Visible = true
          number_of_sheets = excel.SheetsInNewWorkbook
          excel.SheetsInNewWorkbook = 1
          workbook = excel.Workbooks.Add
          excel.SheetsInNewWorkbook = number_of_sheets
      	ws = workbook.Worksheets(1)
      ws.Cells(1,1).Value = b
        # workbook.SaveAs({C;\TestFolder\}  b & ".xlsx")#trying to get 'Customer Address' as the saved workbook
          ## workbook.SaveAs("#{pwd}whatever.xlsx",
      • Dan RathbunD Offline
        Dan Rathbun
        (http://sketchucation.com/forums/viewtopic.php?f)":2b5xebzl]
        (3) require statements are always best located at the top of a file, since they should be dependencies. If they cannot be loaded, the rest of the script should not be run, because a LoadError exception will be raised.
        I'm not here much anymore.
          Dan Rathbun
          FYI
          • [Workbook.SaveAs Method (Excel)](http://msdn.microsoft.com/en-us/library/ff841185(v)
          • [Workbook.Close Method (Excel)](http://msdn.microsoft.com/en-us/library/ff838613(v)
          • [XlFileFormat Enumeration (Excel)](http://msdn.microsoft.com/en-us/library/ff198017(v)
          (1) Always pass SketchUp API class Length instances to input boxes. And then convert back to Float, if needed. (That way users can use whatever the model units are, in the input box entry controls.)
          (2) I think you want XL file format number 60
          Try the following.
          (I cannot test it because I haven't run the Office Home "Click-to-Run" installer yet on my machine.)
          require('win32ole')
          def make_wookbook()
            prompts = [
              "Customer Address"
            defaults = [
              3.0.to_l,
              "Howdy"
            input = UI.inputbox( prompts, defaults, "Stair Info" )
            if input # check validity
              a,b = input
              if defined?(WIN32OLE)
                workbook.Activate
                sheet = workbook.Worksheets(1)
                sheet.Activate
                sheet.Range("B2").Value = b.to_f
                home = ENV["HOME"] || ENV["USERPROFILE"]
                sdir = "TestFolder"
                name = "CustAddy.xlsx"
                path = "#{home}\\Documents\\#{sdir}"
                if Kernel.test(?d,path)
                  filepath = "#{path}\\#{name}"
                elsif Kernel.test(?d, File.dirname(path))
                  filepath = "#{File.dirname(path)}\\#{name}"
                else
                  if UI.respond_to?(;select_directory)
                    path = UI.select_directory(
                      title; "Select SpreadSheet Directory",
                      directory; "#{home}\\Documents"
                    return false unless path
                    else
                      return false
                  else # pre SU2015
                    path = UI.savepanel(
                      "Save SpreadSheet As",
                      "#{home}\\Documents",
                      "#{name}"
                      filepath = path
                    else
                      return false
                workbook.SaveAs(
                  filepath,
                  60 # xlOpenDocumentSpreadsheet
                excel.ActiveWorkbook.Close()
                excel.Quit()
              else
                puts("The WIN32OLE class could not be defined!")
            end # if input valid
          end # method()
            Dan Rathbun
            Oh and ..
            (3) Always save files within the User's path to avoid permission issues.
              davesexcel
              Right on, thanks!
