    [Plugin] S4u Make Face
    56 Posts 28 Posters 274.8k Views 28 Watching
    • hdpvH Offline
      hdpv
      S4u Make Face v3.0.2
      -Support Sketchup 2016 Signed Extension Policy.
      -Language : Français,Espagnol,German
      S4u Make Face v3.0.0
      Fix Bug
      link download:
      http://sketchucation.com/pluginstore?pln=s4u_MakeFace
      https://extensions.sketchup.com/extension/440d2795-e729-42aa-81a2-2ba7df92ecc9/s4u-make-face-5
      S4u Make Face v2.0.0
      -Optimization
      -Espagnol language.
      S4u Make Face v1.0.0
      Select edges for Make Faces
      Automatic exclude edges that its won't make face.
      link download:
      [attachment=0:2xhs2yp3]<!-- ia0 -->s4u_makeface_v1.0.0.rbz<!-- ia0 -->[/attachment:2xhs2yp3]
      Suforyou
      http://www.sketchupforyou.com
      • OxerO Offline
        Oxer
        Thanks for the plugin, here the Spanish Language
        Spanish Language
        http://www.oxervision.blogspot.com/
        • KrisidiousK Offline
          Krisidious
          SCHWEEEET!
          By: Kristoff Rand
            Does this normal?
            Removal is not automatic : you must Press the Key Delete function?
            no_face_segment.skp
            • BoxB Offline
              Pilou I think you'll find it's just slightly incorrect wording.
              The plugin automatically retains the selection of the loose edges so they can be easily deleted.
              It would actually be counterproductive in many cases if the edges were automatically deleted without giving you a choice.
              • JQLJ Offline
                JQL
                That is one of the features that makes this different from any other plugin for face making I know of...
                Well done!
                www.casca.pt
                Visit us on facebook!
                • hdpvH Offline
                  hdpv
                  Thanks Oxer! I will add it new update version.
                  Hi Pilou! My word is incorrect.
                  "That is one of the features that makes this different from any other plugin..." is my mind. 😄
                  Suforyou
                  • I Offline
                    ideas_arte
                    [attachment=0:1xlaqm1z]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:1xlaqm1z]
                    ¡Muchas gracias Oxer!
                    • JQLJ Offline
                      JQL
                      hdpv,
                      I noticed there's no menu entry for this plugin. Is this true? Can you make one?
                      I'm asking for this as it would be great to assign a shortcut to the tool...
                      Thanks,
                      João
                      www.casca.pt
                      • hdpvH Offline
                        hdpv
                        Hi JQL!
                        Menus PLugins>> Suforyou >> Make Face
                        I have update the s4u_MakeFace 2.0.0
                        -Optimization
                        -Espagnol language.
                        Suforyou
                        • JQLJ Offline
                          JQL
                          Nice!
                          www.casca.pt
                          • kenK Offline
                            ken
                            OK, downloaded the new version, V2.0.0. Was testing the plugin. Now after the installation, if I use the plugin, Sketchup has bug splat after closing. And installing this plugin was the only operation in Sketchup I have done this morning. If I open Sketchup and do not use this plugin, Sketchup closes correctly.
                            As for an error code, none displayed. Just the Bug Splat form as shown.
                            Note the prior version did not cause a bug splat.
                            Houston we have a problem.
                            Ken
                            • BoxB Offline
                              Yep, I can confirm what Ken says, it is a repeatable bugsplat.
                              • hdpvH Offline
                                hdpv
                                Hi all!
                                I have post the version 1.0.0 while i find this error.
                                Suforyou
                                  mokhtar
                                  First, Thanks so much for you job on plugins HDVP, really all the plugins that you did so amazing and very useful 😄.
                                  Second, I wanted to ask you about a problem in S4U MakeFace 2.00 because really i can't resolve it, I don't why it don't make all the edges and just some edges like its appear in the attachment ?
                                  S4U MakeFace problem
                                  • BoxB Offline
                                    At a guess it looks like you are trying to work at too small a scale.
                                    If the piece is very small the faces can't form.
                                    Try scaling up by 10 and trying again.
                                    • hdpvH Offline
                                      hdpv
                                      @mokhtar : Can you post your sketchup file?
                                      Suforyou
                                      • hdpvH Offline
                                        hdpv
                                        Update s4u MakeFace v3.0.0
                                        FixBug crash Sketchup!
                                        Suforyou
                                        • E Offline
                                          Esense3d
                                          Thank You
                                          German Language File
                                            French UI 😉
                                            fr.zip
                                            • 1 / 3
