    Newby Ruby "Undefined Method" issue
    3 Posts 3 Posters 806 Views 3 Watching
      sandstorm06
      First time post!
      I am doing an exercise in Automatic SketchUp, and I running into an issue.
      When I preform the 'pushpull' method, I am presented the the "undefined method" error.
      I am writing exactly what the exercise has written, but I am stumped with this error.
      Thank you
        Jim
        The error is telling you the variable hex_face is nil rather than a Sketchup::Face object. So your next step in debugging is to understand why hex_face is not a Face object.
        For a short piece of code like this, simply inspecting the variables after each line might be helpful.
          mcekk
          The code is good. From the console it appears that the first run was ok, and then you ran again the script and the face cannot be created. The problem is that you are trying to create a face object in the same place occupied by the face created before. Clean all your objects first (select all> delete), and try again.
          Manuel Eguia
          Associate Professor
          University of Quilmes
