    [Plugin][$] S4u_Slice
    48 Posts 23 Posters 70.0k Views 23 Watching
    • hdpvH Offline
      hdpv
      S4u_Slice
      Slice,Cut,Detach objects -Set plane by 2 points , 3 points or by Object -Add section faces .Create Group Section.
      • Set plane by 2 points, 3 points or by Edge,Face,Guide line,Axis
      • Add section faces
      • Select Objects and Section Plane for Create Group Section
        (Put Create Group Section in the new layer and show only in the selected Screen)
        Shortcut:
        Ctrl (Alt on Mac) > Lock Zaxis
        Alt (Control on Mac) > Set plane by Object
        Tab > Change cut side
        Shift > Lock Section Plane
      http://s3-us-west-2.amazonaws.com/assets.sketchup.com/web/ewh/s3fs-public/s3fs-public/slice.gif
      Suforyou
      http://www.sketchupforyou.com
      • KrisidiousK Offline
        Krisidious
        πŸ‘
        By: Kristoff Rand
        • F Offline
          function
          ah great! this is like super-zorro. the detach also feature is also very clever
          S4u_Samurai
          • hdpvH Offline
            hdpv
            Thanks,
            Samurai is nice name, πŸ˜„
            Suforyou
              chris87
              Load error (sketchup 8 pro) :
              Erreur de chargement du fichier E:/3D/SKETCH-UP-PRO-8/Plugins/s4u_slice/s4u_slice_menu.rb
              (eval):418:in require': compile error (eval):251: syntax error, unexpected ')', expecting '=' (eval):418: syntax error, unexpected kEND, expecting $endErreur de chargement du fichier s4u_slice.rb (eval):418:in require': compile error
                From the video seems the volumes resulting not "solid" ! ?
                • hdpvH Offline
                  hdpv
                  Thank Chris87! I have fixed it,try again
                  Hi Pilou!
                  It's only add line on face,no solid.
                  Suforyou
                    chris87
                    Hi Pilou!
                    Thank you.....it works fine now !
                    Great plugin !!!
                    • G Offline
                      g.moggel
                      hi
                      trying this with a fairly complex model where zorro always fails. will report back.
                      its really awesome and promising. tried it out in a small file with a few components inside groups and other components - a lot of nesting - and it works fine.
                      thx so far.
                      mo
                      • hdpvH Offline
                        hdpv
                        Good news,Mo!
                        I like Zorro but sometime it's cause crash sketchup.
                        so I make this plugin
                        Suforyou
                        • pbacotP Offline
                          testing in Mac
                          Error Loading File /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/s4u_slice/s4u_slice_menu.rb
                          undefined method instance_variable_defined?' for S4U:ModuleError Loading File s4u_slice.rb undefined method instance_variable_defined?' for S4U:Module
                          • pbacotP Offline
                            Great. Thanks! This seems to work on the Mac--as I understand the plugin so far.
                              Cool one! πŸ˜„
                              Ps Don't work very well with cylinders! πŸ˜‰
                              Random Painter By Chris Fullmer (not sure that it's works in 2014! πŸ˜’
                              Exploded View by CPlassais / Pilou
                              • W Offline
                                within
                                Would be great "Cap hole" option after "cut" and "detach". Excellent plug-in! Thanks!
                                  Done for the Slice 2.0 πŸ˜‰ Soon released!
                                  πŸ‘ 😎
                                  Just a question : when you slice a volume in 2 parts A & B
                                  How choice to keep B ? In your video you keep A πŸ˜‰ (minute 0.10)
                                  Edit : found! Just draw the line slice from top to bottom or bottom to Top !!!
                                  Excellent! πŸ€“
                                  • hdpvH Offline
                                    hdpv
                                    Thank Pilou for review!
                                    I have updated s4u_Slice v2.0.0
                                    Suforyou
                                    • sumasterS Offline
                                      sumaster
                                      HI Su for you,
                                      thank you . . . . . . . πŸ˜„ πŸ‘ πŸ‘ πŸ‘
                                      Thank you,
                                      SUmaster
                                        balci58
                                        perfect plugin, thank you hdpv. Great work!
                                        • G Offline
                                          g.moggel
                                          this really is amazing. i tried some more and i can say bravo. shut up and take my money. seriously though where can i buy and when will the trial expire?
                                          i have a huge model and trying to slice it in one piece makes su crash. but taking larger groups by groups its working amazingly well. thanks soooo much. all the best.
                                          mo
                                          • deaneauD Offline
                                            deaneau
                                            @hdpv said:
                                            Thanks Mo!
                                            Please send paypal: suforyou.vn @ gmail.com 7$ to get it.
                                            Hello hdpv,
                                            what do you think about, to write the minimum donation price in your pluginΒ΄s info?
                                            this will help SketchupUsers (professional or hobbyist) to calculate and find important infos faster.
                                            thank you Dean
                                            MADE, BORN AND LIVING IN BERLIN
                                            Big Thank You to all Programmers
                                            Some German words are so long that they have a perspective. M.Twain
                                            • 1 / 3
