    How to attach text to a line
    3 Posts 2 Posters 648 Views 2 Watching
    • P Offline
      penpendrum
      I want to attach a text to a line and the text would follow the line even if I move or rotate it.
      I also want the text to become smaller when I zoom out if this is possible. .
      I it also possible for the text not to follow the camera angle?
      I know that this is easy if we will just click the text button and then click on the line.
      but how do I do this with ruby scripts?
      I tried to write this script but this does not seem to give me my desired result:
      here is my ruby script:
      model = Sketchup.active_model
      entities = model.entities
      selection = model.selection
      A = entities[0].end.position
      B = entities[0].start.position
      coordinates = [(A.x+B.x)/2,(A.y+B.y)/2,(A.z+B.z)/2]
      point = Geom::Point3d.new coordinates
      text = entities.add_text "Tae", point,[0,2,5]
           text.display_leader= false
      please bare with me I am just a newbie ruby programmer: πŸ˜„
      • Dan RathbunD Offline
        Dan Rathbun
        (1) Do not use capital letters for variables. A and B become constants which are also class and module names.
        (2) code within your own unique namespace module, and separate your various plugins into sub-modules.
        module Penpendrum
          module TextWizard
            # code goes in here
          end # sub-module
        end # module
        (3) Create an empty group
        grp = entities.add_group
        (4) Add your edge and text into the group's entities
        grp.entities.add_line(start,end)
        Then calc the midpoint coordinates
        (5) use 3Dtext instead of a text callout
        text = grp.entities.add_group text.entities.add_3d_text("Tae",TextAlignCenter,"Arial",true, false, 1.0) text.transform!(coordinates)
        Your object is a group with an edge, and a 3d text sub-group (with the 3D text primitives inside it.)
        I'm not here much anymore.
        • P Offline
          penpendrum
          I'm sorry I have tried that .. but that is not what is in my mind.. I just want the text to follow the line even if I move one point only . . doing this manually is possible.. but not for ruby scripts I think..
