    WebDialog input text and the single quote.
    5 Posts 3 Posters 692 Views 3 Watching
    • sdmitchS Offline
      sdmitch
      Is there some reason that a single quote can not be used in a input text box in a webdialog?
      I was working on a WebDialog and attempted to enter a value in feet rather than inches but got an error due to the data string from a submit button being empty. It seems that 60" is ok but 5' isn't. However 5' is ok.
      The following code can be used to demonstrate.
      def webdialog()
       @dlg=UI;;WebDialog.new("TESTING", false,"WDID",300,200,10,10,true)
       @dlg.set_html(
        "<html>
         <body>
          <form action='skp;wd_data@'>
           <input type='text' name='tb1' value='60' size=1 > TextBox One</input><br>
           <input type='submit' name='submit' value='Go' />
          </form>
         </body>
        </html>"
       RUBY_PLATFORM =~ /(darwin)/ ? @dlg.show_modal() ; @dlg.show()
       @dlg.add_action_callback("wd_data") {|d,p|
        if p
         puts p
        else
         puts "p was empty"
      http://sdmitch.blogspot.com/
        Anton_S
        The reason you can't use ' is because its an escape character in your string:
        Whenever you wan't to get element value, use dlg.get_element_value('element_id') It handles escape characters like a charm.
        So, if want to get your element value whenever "ws_data" is called, do this:
        <span class="syntaxdefault"><br /></span><span class="syntaxkeyword">@</span><span class="syntaxdefault">dlg</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_action_callback</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"wd_data"</span><span class="syntaxkeyword">){</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">d</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">p</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">  text </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">get_element_value</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'tb1'</span><span class="syntaxkeyword">)<br />}&nbsp;</span><span class="syntaxdefault"></span>
        Make sure to avoid passing text value to the callback; this will prevent the error.
        • sdmitchS Offline
          sdmitch
          Thanks Anton, that does work. Early on I had problems using .get_element_value so I never thought about it again opting to get the values from the "p" string. I guess it was just beginners bad luck.
          • tt_suT Offline
            tt_su
            What problem was that?
            I also utilize get_element_value for callbacks from JS to Ruby. I use a bridge that convert basic Ruby and JS objects back and forth with synchronous callback on both platform. Using an input element as data transfer is my standard technique.
            • sdmitchS Offline
              sdmitch
              It was very early in my plugin career and involved radio buttons. As soon as I found something else that worked, I never tried using it again. I'm sure it was mostly, if not all, operator error.
