    Iterate selection
    3 Posts 2 Posters 447 Views 2 Watching
    • F Offline
      Frankn
      As the title implies I'm trying to iterate a selected component to retrieve the subcomponents. I use this code to iterate the whole model but can't figure out how to do it for only selected components.
      @component_list=definitions.find_all() {|e| e.entities.find()}.map() {|e| e.instances }.flatten
        Anton_S
        You can do it recursively
        def iterate_ents(ents = Sketchup.active_model.selection)
          ents.each { |e|
            if e.is_a?(Sketchup;;Group)
              iterate_ents(e.entities)
              next
            if e.is_a?(Sketchup;;ComponentInstance)
              iterate_ents(e.definition.entities)
              next
            # Do something here...
        So to get all sub-components you can do it this way:
        def get_all_sub_components(ents = Sketchup.active_model.selection)
          sub_components = []
          ents.each { |e|
        	  sub_components.concat get_all_sub_components(e.definition.entities)
        	  sub_components << e
        	elsif e.is_a?(Sketchup;;Group)
        	  sub_components.concat get_all_sub_components(e.entities)
          sub_components.uniq
        • F Offline
          Frankn
          Thanks Anton_s!
          Even though I'm still trying to figure out what and how your code works it does work perfectly! πŸ˜„
