    [Plugin] Tube cutting optimisation
    22 Posts 4 Posters 3.8k Views 4 Watching
    • inteloideI Offline
      inteloide
      Hello,
      This is my new plugin 'Tube cutting optimisation'.
      This plugin allows you to list usage of a components (tube or whatever scaled in your model) and optimize the cutting of it.
      For example, if you use tube to build an object, just by copy/paste it and scale it through one direction, this plugin will list the number of tube you used and size of each tube.
      PS : tube can be based on square, circle, or whatever shape you want, the key thing is to always stretch it in the same axis in your model (you can turn it also in your model, no problem).
      Also this plugin allows you to optimize the cutting of these tubes with a defined un-cut tube size and a allowable loss.
      NB: "tubes" are actually a component scaled always in the same axis.
      See video and help file for more explainations.
      Note that anonymous data (for statistics usage) are collected. All can be seen on http://bgsketchup.esy.es/index_tube_cutting_optimization.php
      [highlight=#ffff00:2ptamou2]DOWNLOAD[/highlight:2ptamou2] :Click here to download it from PluginStore
      Thank you.
      Best regards.
      Inteloide (BGSketchup)
      Help file
      Screenshot
      History :
      1.6.1 (03/09/2014)
      CORRECTED : Prevent error when calculation is on selected entities
      CORRECTED : Design issue on update splash screen
      CORRECTED : Little issue in stats system
      1.6.0 (31/08/2014)
      ADDED : Translation in French. Other translations can be proposed by used in translating file BGSketchup/Tube_cutting_optimisation/Rb/Localization.rb
      ADDED : Link to help file in status bar
      ADDED : Help file directly into the plugin rbz file
      CORRECTED : "Check for update option" didn't work, now solve
      OPTIMIZED : Optimized scripts for statistics
      1.5.0 (28/08/2014)
      ADDED : Allows to list components only in entities selected in model
      ADDED : Unscaled length of component information added as per JClement request.
      ADDED : Ask to stop calculation if too long (30sec)
      ADDED : Check for updates on startup (with option to disable this function)
      ADDED : Statistics following : IP as user indentifier, date, language, SU version, plugin version, sketchup licence, computer platform. Database can be seen on http://bgsketchup.esy.es/index_tube_cutting_optimization.php
      OPTIMIZED : Export of part list and optimisation list are now proposed to be saved in model's folder.
      CORRECTED : Part list and optimization list now fit window width
      CORRECTED : Some webdialog design optimizations
      CORRECTED : Prevent from error when not selecting a component in the model
      1.4.0 (18/08/2014)
      ADDED :		Allow possibility to have mutli-size of tube for cut optimization
      		ADDED :		For multi tube cutting : plugin ask if priority is to cut the smallest non-cut tubes
      		ADDED :		Options management (For multi tube cutting)
      		ADDED :		Very little help adding in status bar when entering tube length
      		CORRECTED :	Fix a bug when uncut tube are longer than all tubes to be cut
      		CORRECTED :	Unit error in part list CSV export
      		OPTIMIZED :	Change interface icons & colors
      1.3.0 (16/08/2014)
      ADDED : Cut width taken into account
      CORRECTED : Errors with inches unit in optimisation. Now user can enter " or ' in tubes' length or loss or cut
      CORRECTED : Scan also groups and other components entities
      CORRECTED : Javascript errors make a bugsplat screen appear
      CORRECTED : Avoid bug with components names
      v1.2.1 (15/08/2014)
      CORRECTED : Avoid issue with model with inches unit
      v1.2.0 (12/08/2014)
      ADDED : Try to find automatically the vector for the component
      CORRECTED : Avoid to auto-open the window at SU launch
      CORRECTED : Prevent having same tube length in list by rounding length before building summary.
      CORRECTED : Prevent bug when introduce length with point separator instead of comma
      v1.1.1 (11/08/2014) :
      CORRECTED : Bug with tube sizes.
      OPTIMIZED : Now use model unit to show size
      v1.1.0 (10/08/2014):
      Add compatbility with SU8.
      Add export possibility.
      v1.0.0 (09/08/2014) :
      Intitial release
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • yorik1984Y Offline
        yorik1984
        http://storage9.static.itmages.ru/i/14/0809/s_1407626671_9529395_6146089d7b.jpeg
        • G Offline
          glro
          i tried
          made this file
          get the following error message
          "optimisation
          14
          Error: #<ArgumentError: wrong number of arguments (1 for 0)>
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:118:in round' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:118:in add_optimisation_in_html'
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:117:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:117:in add_optimisation_in_html'
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:109:in each' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:109:in add_optimisation_in_html'
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:53:in optimisation' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:35:in show_hide_window'
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:118:in `call'
          C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/BGSketchup/Tube_cutting_optimisation/Rb/Main.rb:118"tube cut opt
            inteloide
            Hello Glro,
            Happy to see you again watching at my plugin ! ;o)
            The error come with SU 8. In SU 2014 the error doesn't appear because SU include a new version of ruby.
            I'll correct this by using other function compatible with SU8.
            I'll post it at same time than a new version which will allow exports in CSV format.
            If you have other idea to improve plugin, as usual you can tell me.
            Inteloide
              inteloide
              Just posted the new version !
              • G Offline
                glro
                @inteloide said:
                Just post the new version !
                Thank you for your plugins; it sounds magical for the user, but i know there is a lot of work behind
                I tried the new version; now it works in SU8; i got the expected result from the model i uploaded previously
                Then i selected one tube and i made it longer; clicked on "calculate/refresh" but the list didn't change
                I realized maybe i had to select the component again by clicking on the button in the up right corner
                i did ... and yes; this time it changed the list, but the result doesn't seem correct
                Besides, by definition, a tube is a structural element that have one dimension much longer than the 2 others; so, would it be possible for the plugin to recognize automatically which dimension is much bigger, without having to define the vector by mouse?
                This program might be useful for scaffolders who use tubes and fittings
                tube cut opt screen shot
                tube cut opt example
                • JClementsJ Offline
                  JClements
                  Please check your personal messages.
                    inteloide
                    Hello !
                    Just post new version !
                    => should work now !
                    => Clever ! I'll try to integrate it in future. The problem is with components with the biggest size not align with an axis of the model (tube created with angle of 45° between "vector" axis and model axis...
                    For JQL :
                    1. Should there be a difference between the sum total units of your script and the outliner?
                    => I have seen the difference but I cannot explain, there are only 15 instance of the component in your model. Can you find other ?
                    1. Can the script be made to read the default unit of measure for the model (the attached model uses inches).
                    => Done
                    1. Would there be a way to input the available lengths of the SOURCE material and calculate the optimize cuts for each? For example, 1x4's in the lumber yard come in lengths of 2 foot increments, starting at 6' up 12'. So I was thinking the user might be able to input something like 6,8,10,12 into a "source material" field of the script and the script would calculate the optimal lumber lengths required and the cut-lengths for each lumber size.
                    => That's much more complicated (another algorithm to develop...) let see in future what I can do.
                    Inteloide
                    • G Offline
                      glro
                      Thank you
                      I tried:
                      the plugin windows opens automatically when sketchup is launched: possible to avoid that? because you don't always need to use the plugin
                      calculate/refresh now works
                      2 lines for tubes same length; possible one line only?
                      in cut optimization, if french is the system language, you have to enter the number with a comma, not a decimal point; otherwise your computer freezes; possible to avoid freezing?
                      i understand the difficulty to retrieve the length when the component doesn't follow main axis; would it be possible to store the tube component axis directly in the sketchup model, so that when you open it again, you don't have to clic again (same component, same axis)
                      also, if the point is to cut the tubes, would it be possible/useful to parameter the cut width?
                      tube cut opt bugs
                        inteloide
                        Hello !
                        Just post new version that solve some of your issue. Main improvement is in vector auto-detection.
                        It try to find which dimension was change between component original definition and the component instance you selected. If within change (you didn't scaled selected component), the plugin try to find the biggest dimension axis in the component. If it's a cube (grrr...) then the plugin doesn't not define a vector, so user must define it. In any case user can change the vector afterward.
                        I take into consideration, for next update, your requests :
                        • add cutting width parameter (should not be so complicated)
                        • Try to develop model structure to look component included in sub-components.
                        • I'll try to implement a option to list only components in selected entities of the model (to avoid listing all "tubes" of the model).
                        See you after some hours of coding ;o)
                        Inteloide
                        • G Offline
                          glro
                          @inteloide said:
                          Hello !
                          Inteloide
                          thank you, you repaired everything
                            JClements
                            I could not get the latest version to accurately work at all.
                            Try the attached file.
                            test 2 for counting component.skp
                            • G Offline
                              glro
                              [attachment=0:q94of7rb]<!-- ia0 -->test 2 for counting component.skp<!-- ia0 -->[/attachment:q94of7rb]
                              downloaded the file
                              plugin didn't work
                              switched units to millimeters
                              the plugin worked...
                              concersion issues...?
                                inteloide
                                Just post version 1.2.1 which correct your bug (html bug actually).
                                Inteloide
                                  inteloide
                                  Big correction just post.
                                  Also cut width function added
                                  Now I'll work on multi-tube lengthes cutting optimization as per JClements request.
                                  Version 1.3.0 Improvements :
                                    inteloide
                                    Hello,
                                    Last version (1.4.0) includes some corrections and optimization.
                                    Mainly (for JClement) it allows to calculate cutting from different uncut tube sizes. Just enter tube sizes with a '/' between each.
                                    In next revision, I'll include a crash preventer function, because, if you enter wrong parameters in tube cutting optimization (for example without a loss allowable and a big number of tubes), you may have some cases where calculation will take hours... For example a model with 30 tubes may have 10^32 solutions to be computed...
                                    Inteloide
                                      JClements
                                      I couldn't get the "slashes" ( / ) to work for multiple source lengths.
                                        inteloide
                                        Hello everybody !
                                        Can somebody try the new version to check if everything goes ok ?
                                        Then I'll post it in pluginstore.
                                        Thank you.
                                        NB : I added an help file to explain how to use it.
                                        Inteloide
                                        • G Offline
                                          glro
                                          @inteloide said:
                                          Hello everybody !
                                          Thank you.
                                          Inteloide
                                          it seems to be working fine
                                          i don't understand the concept of "waste allowed", though
                                          since the goal is to minimize the waste (loss...)it should be put at 0 everytime, no?
                                          what is the use of a limit?
                                          i tried to change it and the result is the same
                                            inteloide
                                            Waste allowed is for the plugin algorithm : if, during calculation, it found a solution with a loss shorter than "allowable waste" then plugin will not to find better solution : it's faster...in some case
                                            • 1 / 2
