    šŸ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Manipulate text label attached to entity
    6 Posts 3 Posters 732 Views 3 Watching
      sepultribe
      Hello all. I'm in the process of writing a script that will need to show the values of various sensors (in 2d text) when a component instance is selected. The component instance represents a sensor node. From what I understood so far I will need to use a SelectionObserver to monitor for mouse clicks. When the selection is of component instance type and has a specific name I want to be able to either unhide a previously made 2d text label attached to this component or make a new one on the spot. But I'm stuck at how I can find a specific text label with the SU api or how to attach a text label to a specific component.
        dacastror
        another option using start_timer and stop_timer
        time = 60 # seconds (will be deactivated in x seconds)
        t = Time.now
        mod = Sketchup.active_model
        ent = mod.entities
        view = mod.active_view
        @text = ent.add_text "", [0,0,0]
        @my_id = UI.start_timer(0.1, true) {
          sel = mod.selection[0]
          if (sel.is_a?(Sketchup;;Group) || sel.is_a?(Sketchup;;ComponentInstance))
            @text.set_text "Position; #{sel.transformation.origin}"
            @text.point = sel.bounds.center
          else
            @text.set_text ""
          view.invalidate
          (UI.stop_timer(@my_id); @text.erase!) if Time.now-t > time
        this code does what you need (if I understood well)
        just need to add the details that all code must have (star_operation, stop_operation put in a definition, ...)
        (google translator)
          dacastror
          probably also will need to add dictionaries to your "nodes" with something like
          entity.set_attribute "dictionaryName", "keyName", ["data", 23, "house"]
            Aerilius
            Hmm, you run the code 600 times (and set each time the same position and text, unless selection is changed)?
            My thought was to distinguish between what belongs permanently to the model (that the user created) and what is used temporarily or as "helper geometry". Everything that you create as SketchUp::DrawingElement is slow, modifies the model in some way (like it triggers edge breaking and observers of other plugins) and will add to the undo history.
            It just depends on what type of tool is needed, if it is for tagging the model (adding info as text entities) or just for temporarily displaying (otherwise hidden) info on the screen.
            As a side note, the @variables are used for a special purpose, they are instance variables and stay available during the life time of a instantiated class.
              dacastror
              This is just a test code that I draw from other code where it was necessary to use @variables, (I forget to delete the unnecessary). This is a slightly better version:
              def change_text(sel,text,view)
                else
                  text.set_text ""
                view.invalidate
              def show_textinfo(time)
                t = Time.now
                mod = Sketchup.active_model;
                sel = mod.selection[0];
                ent = mod.entities;
                tools = mod.tools;
                mod.start_operation("position",false,false,true)
                  Sketchup.send_action "selectSelectionTool;" unless tools.active_tool_id == 21022
                  unless sel == mod.selection[0]
                  (UI.stop_timer(my_id); text.erase!; mod.commit_operation) if Time.now-t > time
              show_textinfo(25) # will run for 25 seconds
              however is better the prospect of creating a tool
              (google translator)
                Aerilius
                Approach with SelectionObserver:
                See the documentation:
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/entities#add_text
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/text
                component # be a reference to your component instance
                position = ORIGIN # or any other point in the component coordinate system
                direction = Geom;;Vector3d.new(0,0,1)
                component.entities.add_text(position, "The label text", direction)
                To find the text again, under the assumption the component contains no other texts:
                in a Selection Observer
                def onSelectionBulkChange(selection)
                  return unless selection.count == 1
                  return unless selection.first.is_a?(Sketchup;;ComponentInstance)
                  component = selection.first
                  return unless component.name == "Specific name"
                  text = component.entities.grep(Sketchup;;Text)
                  # Do something with the text
                As I understand your request, you just want to display information to the user, but you do not want to modify/edit the model file. I strongly suggest not to use the native selection tool and observers for this, because it would run always when the user uses the native Select Tool (with a different intention in mind), and observers run always if not properly attached and removed. Plugins should use observers as little as possible (in terms of time), namely only when the user explicitely launches the plugin.
                Approach with a SketchUp Tool:
                You could write your own tool instead, which allows you to draw your information to the screen, instead of "modeling" text by adding entities to the model. It is also much cleaner because the user can unselect your tool and use the native Select Tool without confusion.
                See for reference:
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/tool
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#draw_text
                http://www.sketchup.com/intl/en/developer/docs/ourdoc/pickhelper#best_picked
                linetool.rb example
                Create a class:
                module Sepultribe
                module SensorNodeInfoPlugin
                class SensorNodeInfoTool
                  SPECIFIC_NAME = "Specific Name"
                  def initialize
                    @selection = nil
                    @info = nil
                  def onLButtonDown(flags, x, y, view)
                    pick_helper = view.pick_helper
                    pick_helper.do_pick(x, y)
                    item = pick_helper.best_picked
                    return unless item.is_a?(Sketchup;;ComponentInstance)
                    return unless item.name == SPECIFIC_NAME
                    # Now you have the right component, store it in an instance variable.
                    @selection = item
                    # Fetch the info that you want to display (assuming you have it stored as attribute)
                    @info = @selection.get_attribute("dictionary_name", "attribute_name", "")
                  def draw(view)
                    return if @selection.nil?
                    position3d = @selection.transformation.origin # or @selection.bounds.center
                    position2d = view.screen_coords(position3d)
                    # (You could also draw the bounding box of the selected component.)
                    # Draw an arrow.
                    vector = Geom;;Vector3d.new(20,-20,0)
                    view.draw2d(GL_LINES, position2d, position2d+vector)
                    # Draw the info.
                    view.draw_text(position2d+vector, @info)
                end # module Sepultribe
                # Add the plugin to the menu, only once when the file is loaded.
                unless file_loaded?(__FILE__)
                  command = UI;;Command.new("Display Sensor Node Info"){
                    Sketchup.active_model.select_tool(SensorNodeInfoTool.new)
                  UI.menu("Plugins").add_item(command)
                end # SensorNodeInfoPlugin
