    Units in the input value through the VCB
    3 Posts 2 Posters 516 Views 2 Watching
    • D
      dacastror
      hi all, I want to ask If at the SketchUp API
      Is there a way to interpret a length inserted through the VCB,
      as when the translation tool is used?
      for example: when the user is working on fractional inch format
      and enter something like 10 1/2 or you're working in centimeters and enter something like 15.3 cm
      my question is:
      Does the API has some input interpreter for a length or should be built?
      Thanks in advance for your help
      (google translator)
      • Dan RathbunD
        Dan Rathbun
        The API adds a to_l method to the standard String class.
        I'm not here much anymore.
        • D
          dacastror
          Dan thanks for replying, I found a recommendation yours here
          http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=55722%26amp;p=505915%26amp;hilit=units+vcb#p505915
          which led me to the article by thomthom
          http://www.thomthom.net/thoughts/2012/08/dealing-with-units-in-sketchup/
          I only have problem for receiving angles values ​​with comma as decimal separator, then I am forced to use the following
          text_input.sub!(',','.') text_input.to_f.degrees
          I do not know if there is a better method
