    How to save the model to a file?
    7 Posts 3 Posters 427 Views 3 Watching
      rvs1977
      Hi!
      How do I save the model to a file?
      I have tried the following but it don't seems to work.
      ` model = Sketchup.active_model
      Save the model using the current SketchUp format
      filename = File.join(ENV['Home'], 'Desktop', 'mysketchup.skp')
      status = model.save(filename)`
      And can anyone tell me what ENV['Home'] is?
      And if I want to save to a diffenrent location than desktop will it then be, eg:
      'c:\my\project\folder'?
      Thanks in advance
      -Rasmus
      Get a Ruby
      • sdmitchS Offline
        sdmitch
        @rvs1977 said:
        Hi!
        Thanks in advance
        -Rasmus
        ENV['Home'] is your user account, ie C:/Users/Rasmus. In this case filename would equal 'C:/Users/Rasmus/Desktop/mysketchup.skp'
        http://sdmitch.blogspot.com/
          rvs1977
          Great, thanks! I figured it out with your help πŸ˜„
          model = Sketchup.active_model status = model.save('d:/rs_model.skp')
          But ENV['Home'] dont seems to work.
          I have tried:
          test = ENV['Home'] puts(test.to_s)
          and nothing shows...
          Get a Ruby
          • sdmitchS Offline
            sdmitch
            I have tried:
            Interesting! In the Ruby Console, type ENV and press Enter. Does that show anything? How about ENV['HOME'].
              rvs1977
              When I type ENV in Ruby Console:
              "PUBLIC"=>"C:\\Users\\Public", "SESSIONNAME"=>"Console", "SystemDrive"=>"C:", "SystemRoot"=>"C:\\windows", "TEMP"=>"C:\\Users\\RASMUS~1\\AppData\\Local\\Temp", "TMP"=>"C:\\Users\\RASMUS~1\\AppData\\Local\\Temp", "USERDOMAIN"=>"RasmusVS-pc-Pc", "USERNAME"=>"RasmusVS-pc", "USERPROFILE"=>"C:\\Users\\RasmusVS-pc", "windir"=>"C:\\windows", "windows_tracing_flags"=>"3", "windows_tracing_logfile"=>"C:\\BVTBin\\Tests\\installpackage\\csilogfile.log"}
              As you can see there is no ENV['Home'] variable.
              I would use ENV['USERPROFILE'] instead.
              I use Sketchup 8.0.15158 - Maybe thats why...?
              Get a Ruby
              • Dan RathbunD Offline
                Dan Rathbun
                %HOME% is not defined under MS Windows by default.
                Beginning with SketchUp 2014, SketchUp defines ENV["HOME"] within it's own copy of the environment, thus:
                ENV["HOME"]= ENV["USERPROFILE"] unless ENV["HOME"]
                Ruby itself needs ENV["HOME"] defined in order to expand ~ (the tilde character,) within path strings, to the user's home directory path.
                We (developers,) asked for this, because we all were trying to set ENV["HOME"].
                Be aware that there are differences in the names of ENV variables, between both OSX and MS Windows, and between Windows 6+ and Windows 5 and earlier versions. See:
                Wikipedia: Environment Variables
                I'm not here much anymore.
                  Dan Rathbun
                  @rvs1977 said:
                  Yes.. as I said above, prior to SKetchUp 2014, we had to make sure ENV["HOME"] was set ourselves (as I showed above.)
                  Ruby needs it set.
