    [plugin] xml parser
    2 Posts 2 Posters 356 Views 2 Watching
    • Q Offline
      qiucx
      I need to save the complex entity of SU to xml and then load them. REXML is too slow, and the libxml-ruby is really hard to compile. Does anyone have the working lib? Or other suggestion?
      thanks.
      • Dan RathbunD Offline
        Dan Rathbun
        Export / Import
        DAE files are XML.
        You can select what you wish to save, and call:
        model.export( "some/path/filename.dae", optshash )
        Create the options hash first with :selectionset_only => true
        Then import them using model.import
        I'm not here much anymore.
