    C API unresolved external symbol
    3 Posts 2 Posters 994 Views 2 Watching
    • G Offline
      Gábor
      I'm trying to compile and build the "Reading from a .skp file" example found at http://www.sketchup.com/intl/en/developer/su-api/
      What I did:
      1. Installed Visual Studio C++ 2010 Express
      2. Downloaded the SDK
      3. Created a blank Win32 Console app and copied the example into it.
      4. Among the project settings set the location for the sdk header and lib files.
      5. Added #include "stdafx.h" as the first line of the example code.
      6. Tried to build.
      7. Got a list of errors:
      d external symbol __imp__SUTerminate referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUModelRelease referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUStringRelease referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUStringGetUTF8 referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUStringGetUTF8Length referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUModelGetName referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUStringCreate referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUVertexGetPosition referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUEdgeGetEndVertex referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUEdgeGetStartVertex referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUFaceGetEdges referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUFaceGetNumEdges referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUEntitiesGetFaces referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUEntitiesGetNumFaces referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUModelGetEntities referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUModelCreateFromFile referenced in function _main
      1>skp demo.obj ; error LNK2019; unresolved external symbol __imp__SUInitialize referenced in function _main
      1>c;\users\user1\documents\visual studio 2010\Projects\skp demo\Debug\skp demo.exe ; fatal error LNK1120; 17 unresolved externals
      ========== Build; 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
      The error messages obviously refer to the implementation of these functions are not found in the library files. I tried to copy the SDK libraries (.lib, .dll) to any directory I could imagine in the search path but still got the same error list on build.
      Any ideas what needs to be done to successfully compile and build the example?
      • AdamBA Offline
        AdamB
        Generally, its better to amend the VS library search path rather than have multiple copies of libs/dlls
        • G Offline
          Gábor
          Thank you AdamB. I did add the path of the downloaded .dll and .lib to the VS library search path.
          Somewhere I read that character encoding differences could cause such error messages. So I also tried to change the project's encoding settings without any luck....
          EDIT: Thank you. SUCCESS!!! (Well it was a missing reference to the lib... 😳 )
