    Delete a mesh square diagonal edge (hidden) ?
    3 Posts 2 Posters 416 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hi,
      i would like to delete teh diagonal in one nesh field of a mesh created by the sandbox,
      to become one squer face with one face.
      is it possible (for co-planar mesh-triangles only, of course)
      thanx
      stan
      • tt_suT
        tt_su
        Loop over the edges in the mesh, find the ones that are soft and smooth - ensure two faces are connected. Then take all the vertices and create a best fit plane and check if all vertices are on the plane - if they are you can erase the edge.
        • artmusicstudioA
          artmusicstudio
          hi tt_su,
          super, soft & smooth helps to identify. it works. the selected field of mesh is tranfered to a single face (i work with selection).
          thanx
          stan
