    Text variable within a component?
    3 Posts 2 Posters 361 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hi,
      is there a ruby-variable, which can show
      the NAME OF THE COMPONENT-INSTANCE
      even when the text (=variable) is placed within the component definition?
      i would like to achieve, that the name of the instance (unique, while created by my ruby, is displayed thru my ruby-script,
      but the text always is moved with the component by the user (it "sricks" to it),
      but i don't want to create a group 'around' them.
      is there any solution for that idea?
      thanx
      stan
      • Dan RathbunD
        Dan Rathbun
        Both the definetion and the instance have their own name() and name=() methods.
        But these attributes are displayed in the EntityInfo dialog. (They are not text objects.)
        You could wrap the instance and a text object within a unique group. Then they would move together.
        I'm not here much anymore.
        • artmusicstudioA
          artmusicstudio
          hi dan,
          yes, i understand.
          i solved the problem with the following solution:
          the component-related text is placed outside
          and with every calculation per ruby it is selectively deleted and placed with new parameters
          at the new components position.
          seems to work well.
          stan
