    Retrieving bounding-box-value from a component instance ?
    3 Posts 2 Posters 396 Views 2 Watching
    • artmusicstudioA
      artmusicstudio
      hi,
      how ever i define the component instance,
      if i retrieve the boundary box from an INSTANCE,
      i get back the values from the DEFINITION.
      which syntax is necessery to call the instance-parameters (especially highest "z" of its BB)
      elsif entity.is_a?(Sketchup;;ComponentInstance)
      	@definition=entity.definition
      	@auswahl=entity.name
      	puts "auswahl_name ; " + @auswahl
      		  #puts "selection = component"
      		  calculation_top_nested_component
      	else
      		  #puts"other element type then face or group or component"
      and so on....
      calling the method [b]calculation_top_nested_component[/b]
      def calculation_top_nested_component
      bbox = @definition.bounds
      z = bbox.max
      puts z
      selection = @definition.entities()
      selection.each { |entity|
      	@auswahl = entity
      and so on
      so @definition always gives the same values for different comonents.
      any idea?
      thanx in advance
      stan
      EDIT: while retrieving information about faces from different instances of a component i found out, that
      always informations from the definition-face will be given back, means: x,y,z is always the same, regardles, where the INSTANCE is placed.
      so probably some transformation parameter have to be added to [x,y,z] to find the real position.
      but how can i read out the transformation of the daughter component (= instance) ???
      • Dan RathbunD
        Dan Rathbun
        The Sketchup::ComponentInstance class inherits a bounds() method from its superclass, Sketchup::Drawingelemnt, just as the Sketchup::ComponentDefinition class does.
        Yes you need to understand transformations.
        TIG has posted many how tos. Use the forum search, or check the Code Snippets index.
        I'm not here much anymore.
        • artmusicstudioA
          artmusicstudio
          hi dan,i willk take a look at it.
          yes, i was searching in the forum in the mean time a lot and found a topic from 2009 whit good ideas.
          i can now identify the component instance and retrieve its own height, especially when it is nested.
          there are still some minor problems , but the ruby returns the informations needed now.
          thanx for helping me!
          stan
