    Ui - messagebox definition
    3 Posts 2 Posters 551 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hi,
      i cannot find anywhere a solution for making a simple
      ui-messagebox with more lines (like a small table)
      i have
      submenu.add_separator
      submenu.add_item("7 support / credits / info"){
      UI.messagebox "1.xxxxxxxxx"
      but showing
      1.xxxxxxxxx
      2.xxxxxxxxx
      3.xxxxxxxxx
      and a simpleok-button.
      is there a way? in the ruby api they speak about a multiline msgbox, but without showing asyntax.
      thanx a lot.
      stan
        Jim
        You can insert a newline using \n
        txt = "This is line one.\nThis is line two"
        UI.messagebox(txt)
          artmusicstudio
          hi jim,
          thank you so much. it works. again a step closer to my ruby.
          stan
